Aller au contenu principal
How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape
Ce dont vous avez besoin
  1. How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape, Emerson VCR953 Top Shell Removal: étape 1, image 1 de 2 How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape, Emerson VCR953 Top Shell Removal: étape 1, image 2 de 2
    • Remove the two 1/2" long #2 Philips screws from the rear of the case
  2. How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape: étape 2, image 1 de 1
    • Lift up on the back case and slide the top case back until it is free from the rest of the case
  3. How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape: étape 3, image 1 de 1
    • You will now have access to all the circuit boards and the top of all mechanical parts.
  4. How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape, How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape: étape 4, image 1 de 1
    • Once the top shell is off you should have access to the read head drum.
    • Read head drum
  5. How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape: étape 5, image 1 de 1
    • Cut a strip of plain white copy paper between 1"-2" tall.
    • Soak the middle of the strip in isopropyl alcohol. 70% will work, but the higher the concentration the better. I used 91% because it is what I had.
    • You want to use paper for this and not something like cotton swabs or pads because they can leave fibers behind on the drum that can damage it or your tapes.
  6. How to Clean a VCR Read Head WIthout a Read Head Cleaner Tape: étape 6, image 1 de 1
    • Wrap the alcohol soaked paper around the read head drum and hold it in place against the drum with your thumb.
    • With the paper pressed against the drum use your other hand to rotate the drum in either direction.
    • Do this until no more dirt is coming off the drum onto the paper. You may need to flip the paper around to allow it to catch more dirt.
4 autres ont terminé cette réparation.
Julian
Membre depuis le 03/23/16
571 Réputation
3 tutoriels rédigés
2 commentaires
Thanks so easy when you are shown
Peter Logan - Réponse
Keeps ejecting tape or stops?
Walter Salter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 75
Total : 2,070
