Aller au contenu principal
How to Clean and Lubricate Skateboard Bearings
Ce dont vous avez besoin
  1. How to Clean and Lubricate Skateboard Bearings, How to Clean and Lubricate Skateboard Bearings: étape 1, image 1 de 2 How to Clean and Lubricate Skateboard Bearings, How to Clean and Lubricate Skateboard Bearings: étape 1, image 2 de 2
    • Remove the wheels from the skateboard by unscrewing the 8mm axle nuts with the adjustable wrench. Make sure to keep all your hardware organized so that nothing gets lost.
    • There should be four wheels, four nuts, and eight washers.
  2. How to Clean and Lubricate Skateboard Bearings: étape 2, image 1 de 2 How to Clean and Lubricate Skateboard Bearings: étape 2, image 2 de 2
    • Pop the bearing out with a thin screwdriver. Go through the wheel to avoid damaging the bearings. Place the bearings next to the hardware.
    • Be careful not to push the screwdriver through the bearing into your hand.
  3. How to Clean and Lubricate Skateboard Bearings: étape 3, image 1 de 3 How to Clean and Lubricate Skateboard Bearings: étape 3, image 2 de 3 How to Clean and Lubricate Skateboard Bearings: étape 3, image 3 de 3
    • Remove the bearing shield with a knife. Starting with the inside ring is the easiest method.
    • Use caution when using sharp tools.
  4. How to Clean and Lubricate Skateboard Bearings: étape 4, image 1 de 3 How to Clean and Lubricate Skateboard Bearings: étape 4, image 2 de 3 How to Clean and Lubricate Skateboard Bearings: étape 4, image 3 de 3
    • Place the bearings and the shields in the container and pour mineral oil in until they are submerged. Place the lid on the container and give it a good shake.
  5. How to Clean and Lubricate Skateboard Bearings: étape 5, image 1 de 1
    • Take the bearings out and dry them off on a rag.
  6. How to Clean and Lubricate Skateboard Bearings: étape 6, image 1 de 2 How to Clean and Lubricate Skateboard Bearings: étape 6, image 2 de 2
    • Take the WD-40 and spray a little bit into each bearing.
  7. How to Clean and Lubricate Skateboard Bearings: étape 7, image 1 de 3 How to Clean and Lubricate Skateboard Bearings: étape 7, image 2 de 3 How to Clean and Lubricate Skateboard Bearings: étape 7, image 3 de 3
    • Place the bearing shields back on the bearings by snapping them back in place.
  8. How to Clean and Lubricate Skateboard Bearings: étape 8, image 1 de 3 How to Clean and Lubricate Skateboard Bearings: étape 8, image 2 de 3 How to Clean and Lubricate Skateboard Bearings: étape 8, image 3 de 3
    • Place the bearings back in the wheels. Using the back part of the screwdriver is the best method.
  9. How to Clean and Lubricate Skateboard Bearings: étape 9, image 1 de 2 How to Clean and Lubricate Skateboard Bearings: étape 9, image 2 de 2
    • Finally, re-assemble the skateboard.
    • Place one wheel on the truck with the washers on each side of the wheel.
    • Use the wrench to screw the nuts so that they are flush with the truck. The wheel should be able to move a little bit.
    • Repeat this step with the other three wheels.
The last step is to re-assemble the skate board. Be sure to place the washers between the trucks and the wheel and between the wheel and the bolt.
Pikes Peak State College
Membre depuis le 03/06/25
169 Réputation
1 tutoriel rédigé
Équipe
Colorado Springs, Team 1-12, Kiser Fall 2024 Membre de l'équipe Colorado Springs, Team 1-12, Kiser Fall 2024
UCCS-KISER-F24S1G12
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 38
Total : 147
