Aller au contenu principal
How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar
Ce dont vous avez besoin
  1. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar, How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 1, image 1 de 2 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar, How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 1, image 2 de 2
    • Clear the workspace of any items or clutter that could damage the finish of the guitar.
    • Support the neck of the guitar with a stand or bag.
    • In this case, a neck stand was not available, so a toiletries bag with towels stuffed inside was used to support the neck of the guitar.
    • You are good to go as long as it is stable and supports the guitar's neck well.
  2. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 2, image 1 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 2, image 2 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 2, image 3 de 3
    • Using the string winder, unwind the strings.
    • It is okay to relieve all of the tension on the neck by unwinding all of the strings at once.
  3. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 3, image 1 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 3, image 2 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 3, image 3 de 3
    • Using the string winder, pull up the bridge pins.
    • Remove the old strings.
    • This allows complete access to clean and oil the frets and fretboard.
  4. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 4, image 1 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 4, image 2 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Microfiber Cleaning Cloths
    $3.99
    J'achète
    • Use a scouring pad to clean and oil the fretboard, frets, and bridge with the Dunlop Lemon Oil.
    • Let the oil sit and seep into the wood for five minutes.
    • This is done so that the oil is absorbed into the wood of the fretboard and bridge, benefitting the longevity and life of the wood.
    • Once done, wipe off all of the excess oil with a microfiber cloth.
  5. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 5, image 1 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 5, image 2 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 5, image 3 de 3
    • It is important to use clean microfiber cloths for this step.
    • Use the Dunlop cleaner to clean the front, back, sides, and neck of the guitar.
    • Finish up with the Dunlop Carnauba wax to polish the front, back, sides, and neck of the guitar.
  6. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 6, image 1 de 2 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 6, image 2 de 2
    • Insert the new strings into the bridge holes.
    • Pop the bridge pins down into place.
    • Make sure to keep tension on the strings as the bridge pins are popped down into place.
  7. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 7, image 1 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 7, image 2 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 7, image 3 de 3
    • Cut the strings to size.
    • For the bass strings, measure one tuner head's length and trim it there.
    • For the treble strings, measure one and a half tuner head's length and trim it there.
    • When inserting the string into the tuning post, the string end should protrude approximately 1/8th of an inch from the tuner hole.
    • The bass side tuning pegs should be turned in a counter-clockwise direction to tune to pitch and the treble side tuning pegs should be turned in a clockwise direction to tune to pitch.
    • Make sure to remember that the wraps around the tuning post must go under the string to properly stay in tune and to avoid creating a kink, which could break the string.
    • Two to three wraps are perfect for the bass strings. The treble strings require approximately six wraps.
  8. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 8, image 1 de 1
    • Use a tuner to tune all of the strings to their proper notes.
    • The standard tuning for a six-string guitar is E A D G B E, which reads from the Low E (6th string) to the High E (1st string).
  9. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 9, image 1 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 9, image 2 de 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 9, image 3 de 3
    • Stretch out each of the strings to help them intonate and stay in tune faster.
    • You will have to tune the guitar multiple times until the strings stay in tune when stretched.
    • Repeat this step until the guitar stays in tune.
  10. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: étape 10, image 1 de 1
    • Enjoy your newly strung, cleaned, and maintained instrument.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Michael Dieguez
Membre depuis le 04/07/21
208 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team S1-G5, Harris Spring 2021 Membre de l'équipe CSU Los Angeles, Team S1-G5, Harris Spring 2021
CSULA-HARRIS-S21S1G5
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 26
Total : 1,391
