Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Clean and Sterilize a Hairbrush
Ce dont vous avez besoin
    1. How to Clean and Sterilize a Hairbrush, How to Clean and Sterilize a Hairbrush: étape 1, image 1 de 3 How to Clean and Sterilize a Hairbrush, How to Clean and Sterilize a Hairbrush: étape 1, image 2 de 3 How to Clean and Sterilize a Hairbrush, How to Clean and Sterilize a Hairbrush: étape 1, image 3 de 3
      • Remove the built-up hair from the brush by inserting the comb into one side of the bristles and pulling up.
      • If you do not have a comb a fork will also work to pull out the built-up hair.
      • You may need to repeat this step a few times in order to remove all of the hair.
      • Do not move on to step two until all of the hair is removed from the brush, the process will not work if all of the hair is not removed
      Demander à FixBot
      Ajouter un commentaire
    2. How to Clean and Sterilize a Hairbrush: étape 2, image 1 de 3 How to Clean and Sterilize a Hairbrush: étape 2, image 2 de 3 How to Clean and Sterilize a Hairbrush: étape 2, image 3 de 3
      • Dampen the bristles of the brush with warm water
      • Add a few drops of soap to the bristles
      • Shampoo, detergent, body wash or any other type of cleanser can also be used in place of soap as long it is not harmful to the body.
      • Work the soap into the brush using your fingers to massage the bristles
      • This will help to remove any dirt and grime that has built up
      • Thoroughly rinse the brush in warm running water
      • Repeat the entirety of this step if the brush does not appear completely clean.
      Demander à FixBot
    3. How to Clean and Sterilize a Hairbrush: étape 3, image 1 de 3 How to Clean and Sterilize a Hairbrush: étape 3, image 2 de 3 How to Clean and Sterilize a Hairbrush: étape 3, image 3 de 3
      • Set the brush aside and fill the large bowl with hot water
      • The bathroom sink can be used in place of the bowl
      • Add ½ cup of white vinegar to the bowl of water
      • The vinegar will work to remove any germs and bacteria from the brush
      • 1/4th cup of ammonia can be used in place of the vinegar or 1/4th ounce of tea tree oil which is a very effective natural sterilizer for hairbrushes 3b. Place the brush into the large bowl with the bristles facing down and let soak for 30 minutes
      • Place the brush into the large bowl with the bristles facing down and let soak for 30 minutes
      • DO NOT exceed the thirty-minute soak time, allowing the brush to soak for longer can cause damage to the rubber cushions
      Demander à FixBot
    4. How to Clean and Sterilize a Hairbrush: étape 4, image 1 de 2 How to Clean and Sterilize a Hairbrush: étape 4, image 2 de 2
      • Remove the brush from the bowl and shake it to remove any excess water
      • Place the brush on the towel bristles down and allow the brush to air dry
      • It will take approximately one hour for the brush to dry, once the brush is dry it is ready to be used again
      • Remember to wash the bowl thoroughly after removing the brush
      Demander à FixBot
This process should be repeated once a month in order to keep the brush in good condition and keep any dirt and grime build up from being transferred onto your hair .
2 autres ont terminé cette réparation.
Delanie Clark
Membre depuis le 12/05/19
172 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 30
30 derniers jours : 76
Total : 1,124
