Aller au contenu principal
How to Clean the Danby Room Air Conditioner Filter
Ce dont vous avez besoin
  1. How to Clean the Danby Room Air Conditioner Filter, How to Clean the Danby Room Air Conditioner Filter: étape 1, image 1 de 1
    • Start by removing the air filtration panel, commonly located on the right side of the air conditioner. Using the little handle, simply pull the filter out.
  2. How to Clean the Danby Room Air Conditioner Filter: étape 2, image 1 de 2 How to Clean the Danby Room Air Conditioner Filter: étape 2, image 2 de 2
    • Gently tap the air filtration panel against the side of a garbage can or disposal area, to get rid of any loose dirt.
    • Using water and a brush of any sort, gently brush away the stubborn dirt.
  3. How to Clean the Danby Room Air Conditioner Filter: étape 3, image 1 de 1
    • Once you have completely removed the dirt, gently dry the filter with a paper towel or dry cloth.
    • Place the filter aside and let it thoroughly dry for 30 minutes to 1 hour.
  4. How to Clean the Danby Room Air Conditioner Filter: étape 4, image 1 de 1
    • After setting aside the filter, use the Phillips #1 screwdriver to remove the two 12.7 mm front panel screws from the air conditioner.
    • Gently pull the front panel off the unit.
  5. How to Clean the Danby Room Air Conditioner Filter: étape 5, image 1 de 3 How to Clean the Danby Room Air Conditioner Filter: étape 5, image 2 de 3 How to Clean the Danby Room Air Conditioner Filter: étape 5, image 3 de 3
    • Clean the front unit with water and a brush, entirely, front and back. Once you finished cleaning the unit, make sure that the wind flaps are properly inserted into their slot and not damaged or moved when cleaning them.
    • Dry the front unit along with the filter anywhere from 30 mins and 1 hour each.
    • As the filter and unit are drying, take a water spray and brush down any dirt that may be clogged in the front panel of the Air Conditioner, till it returns to its original color. Then let the panel dry for 15-30 minutes.
  6. How to Clean the Danby Room Air Conditioner Filter: étape 6, image 1 de 1
    • Once all three pieces (the air filter, front unit, and front panel) are all completely dried, simply screw back the front unit, and then re-insert the air filter into the side.
To Reassemble the front unit. Simple screw back the front unit and reinsert the filteration
2 autres ont terminé cette réparation.
Kiranteja Gundloory
Membre depuis le 07/05/21
157 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G31, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S2-G31, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G31
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 71
30 derniers jours : 220
Total : 5,610
