Aller au contenu principal
How to Clean the InFocus X2 Lamp Housing Screens
Ce dont vous avez besoin
  1. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: étape 1, image 1 de 3 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: étape 1, image 2 de 3 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: étape 1, image 3 de 3
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: étape 2, image 1 de 3 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: étape 2, image 2 de 3 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: étape 2, image 3 de 3
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: étape 3, image 1 de 3 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: étape 3, image 2 de 3 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: étape 3, image 3 de 3
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. How to Clean the InFocus X2 Lamp Housing Screens, Remove the Old Lamp: étape 4, image 1 de 1
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. How to Clean the InFocus X2 Lamp Housing Screens, Insert the New Lamp: étape 5, image 1 de 1
    • Insert the replacement lamp into the projector.
  6. How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: étape 6, image 1 de 2 How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: étape 6, image 2 de 2
    • Use a vacuum cleaner to gently suck up the dust on the front and the back Lamp Housing screens.
Pièces jointes
Paulina Duarte
Membre depuis le 09/19/13
553 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Membre de l'équipe UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 167
