Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Darn a Hole in Denim Jeans by Hand
Ce dont vous avez besoin
    1. How to Darn a Hole in Denim Jeans by Hand, How to Darn a Hole in Denim Jeans by Hand: étape 1, image 1 de 1
      • Gather your jeans needing repair and locate the hole to be darned.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Darn a Hole in Denim Jeans by Hand: étape 2, image 1 de 3 How to Darn a Hole in Denim Jeans by Hand: étape 2, image 2 de 3 How to Darn a Hole in Denim Jeans by Hand: étape 2, image 3 de 3
      • Using a pair of scissors, trim away any loose and frayed ends.
      • These are ends that would have formed from the ripping of the denim fabric.
      Demander à FixBot
    3. How to Darn a Hole in Denim Jeans by Hand: étape 3, image 1 de 1
      • Match a thread color to the color of the denim you are repairing.
      • For a sleeker and less visible repair use a thread with a smaller strand count.
      • I used a thicker and more visible color for the purpose of making the stitching easier to see in this guide.
      Demander à FixBot
    4. How to Darn a Hole in Denim Jeans by Hand: étape 4, image 1 de 1
      • Cut a patch from a similar colored piece of denim.
      • The patch should be longer than the hole on all sides by at least 1/2 inch.
      Demander à FixBot
    5. How to Darn a Hole in Denim Jeans by Hand: étape 5, image 1 de 2 How to Darn a Hole in Denim Jeans by Hand: étape 5, image 2 de 2
      • Turn the jeans inside out and use pins to attach the patch to cover the hole.
      Demander à FixBot
    6. How to Darn a Hole in Denim Jeans by Hand: étape 6, image 1 de 2 How to Darn a Hole in Denim Jeans by Hand: étape 6, image 2 de 2
      • Thread your needle with the thread you chose in Step 3.
      • Cut about 3 feet of your thread and tie a small square knot just big enough to not pull through your fabric.
      • You may need to double, triple, or even quadruple knot the thread to not pull through, depending on the gauge of thread you chose to lose.
      Demander à FixBot
    7. How to Darn a Hole in Denim Jeans by Hand: étape 7, image 1 de 3 How to Darn a Hole in Denim Jeans by Hand: étape 7, image 2 de 3 How to Darn a Hole in Denim Jeans by Hand: étape 7, image 3 de 3
      • From the inside insert the needle and pull the thread through completely until the knot is tight against the fabric.
      • Repeat the process by pulling the thread from the outside back to the inside until there is a line formed with your thread.
      Demander à FixBot
    8. How to Darn a Hole in Denim Jeans by Hand: étape 8, image 1 de 3 How to Darn a Hole in Denim Jeans by Hand: étape 8, image 2 de 3 How to Darn a Hole in Denim Jeans by Hand: étape 8, image 3 de 3
      • Continue the process shown in Step 7 for the entire perimeter of the patch.
      • Once completed, the patch should be fully attached to the jeans.
      Demander à FixBot
    9. How to Darn a Hole in Denim Jeans by Hand: étape 9, image 1 de 1
      • Now that the patch is fully attached, turn the jeans right side out.
      • Insert your needle from the inside of the jeans about 1/2 inch above the top of the hole and 1/2 inch to one side of the hole.
      • Pull the thread tight and insert the needle again on the other side of the hole about 1/2 and inch in the opposite direction.
      • This should create a stitch or a line of thread across the top of the hole.
      • Repeat the process to create enough stitches to cover the entire length of the hole.
      Demander à FixBot
    10. How to Darn a Hole in Denim Jeans by Hand: étape 10, image 1 de 2 How to Darn a Hole in Denim Jeans by Hand: étape 10, image 2 de 2
      • Once you have covered the hole completely with thread using lines in one direction, you will weave your needle above and under the stitches you formed in the last step.
      • Begin by putting your needle under the stitch closest and then over the next stitch and under the following, so forth and so on.
      • Continue this process for the entire width of the hole.
      • When you reach your final stitch you will pull your thread tight and begin again from the other direction.
      • Once this is completed, you should insert your needle, pull the thread tight inside the jeans, knot off your thread and cut the excess.
      Demander à FixBot
The hole should now be completely repaired and be back to regular function.
4 autres ont terminé cette réparation.
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 36
30 derniers jours : 155
Total : 25,684
