Aller au contenu principal
How to Deep Clean a Mechanical Keyboard
Ce dont vous avez besoin
  1. How to Deep Clean a Mechanical Keyboard, How to Deep Clean a Mechanical Keyboard: étape 1, image 1 de 1
    • Take a picture of the keyboard for future reference.
    • This is to ensure that all keys return to the correct place.
  2. How to Deep Clean a Mechanical Keyboard: étape 2, image 1 de 3 How to Deep Clean a Mechanical Keyboard: étape 2, image 2 de 3 How to Deep Clean a Mechanical Keyboard: étape 2, image 3 de 3
    • Use keycap puller to pull the keys off gently.
    • Some keys are harder to pull so adjust your strength accordingly.
    • Place them in the bowl.
  3. How to Deep Clean a Mechanical Keyboard: étape 3, image 1 de 2 How to Deep Clean a Mechanical Keyboard: étape 3, image 2 de 2
    • Flip the keyboard over.
    • Tap it and let all the dirt fall off.
  4. How to Deep Clean a Mechanical Keyboard: étape 4, image 1 de 3 How to Deep Clean a Mechanical Keyboard: étape 4, image 2 de 3 How to Deep Clean a Mechanical Keyboard: étape 4, image 3 de 3
    • Scrub the rows with a dry toothbrush gently.
    • Use tweezer to get gunk out of hard to reach areas.
    • Scrub away any left over dirt that is still visible.
    • Use a cotton swab dipped in isopropyl alcohol for maximize cleanliness.
  5. How to Deep Clean a Mechanical Keyboard: étape 5, image 1 de 1
    • Use a can of compress air to further clean the keyboard.
    • Use this in tight areas such as in between key switches.
  6. How to Deep Clean a Mechanical Keyboard: étape 6, image 1 de 2 How to Deep Clean a Mechanical Keyboard: étape 6, image 2 de 2
    • Fill the bowl with lukewarm water and add soap.
    • Use the toothbrush to gently scrub the keys.
    • Scrub all sides to ensure absolute cleanliness.
  7. How to Deep Clean a Mechanical Keyboard: étape 7, image 1 de 2 How to Deep Clean a Mechanical Keyboard: étape 7, image 2 de 2
    • Soak the keys in the soap bath for 5 minutes.
    • Rinse the keys with lukewarm water.
    • Make sure there is no soap left.
  8. How to Deep Clean a Mechanical Keyboard: étape 8, image 1 de 3 How to Deep Clean a Mechanical Keyboard: étape 8, image 2 de 3 How to Deep Clean a Mechanical Keyboard: étape 8, image 3 de 3
    • Lay the keys letters-side up on the towel.
    • Let them completely dry.
    • Gather the towel corners and make a sack.
    • Shake the keys vigorously to ensure faster dry time.
  9. How to Deep Clean a Mechanical Keyboard: étape 9, image 1 de 3 How to Deep Clean a Mechanical Keyboard: étape 9, image 2 de 3 How to Deep Clean a Mechanical Keyboard: étape 9, image 3 de 3
    • Use Step 1 to re-assemble the keyboard.
    • Test the keys to check for faultiness.
Aye, you did it! Pat yourself on the back for the hard work you have done today. Hopefully, you will gain an understanding of how to maintain your keyboard. Thank you so much for choosing this particular guide. Have a wonderful day!
2 autres ont terminé cette réparation.
Capreil Joseph
Membre depuis le 10/23/23
187 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 2-11, Bennett Fall 2023 Membre de l'équipe Sam Houston State, Team 2-11, Bennett Fall 2023
SHSU-BENNETT-F23S2G11
2 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 84
Total : 298
