Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Descale a Breville Barista Pro BES878-RVC
Ce dont vous avez besoin
    1. How to Descale a Breville Barista Pro BES878-RVC, How to Descale a Breville Barista Pro BES878-RVC: étape 1, image 1 de 1
      • Press the power button to power on the espresso machine.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Descale a Breville Barista Pro BES878-RVC: étape 2, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 2, image 2 de 2
      • Pull out and empty the water tank and drip tray.
      Demander à FixBot
    3. How to Descale a Breville Barista Pro BES878-RVC: étape 3, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 3, image 2 de 2
      • Pull out the water filter from the water tank.
      Demander à FixBot
    4. How to Descale a Breville Barista Pro BES878-RVC: étape 4, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 4, image 2 de 2
      • Pour a packet of descaler (or a descaler tablet) into the water tank.
      • Fill the water tank with fresh water to the descale line located on the side of the water tank.
      • If you do not have a descaler, pour a 1:1 mixture of white vinegar and water into the water tank instead.
      Demander à FixBot
    5. How to Descale a Breville Barista Pro BES878-RVC: étape 5, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 5, image 2 de 2
      • Reinsert water tank and drip tray.
      Demander à FixBot
    6. How to Descale a Breville Barista Pro BES878-RVC: étape 6, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 6, image 2 de 2
      • Position the steam wand above the drip tray.
      • If you wish to prevent splashing, place a tall bowl or cup under the steam wand.
      Demander à FixBot
    7. How to Descale a Breville Barista Pro BES878-RVC: étape 7, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 7, image 2 de 2
      • Press the menu button.
      • Turn the knob labelled “Filter Size” counterclockwise until the “descale” label is blinking on the display.
      Demander à FixBot
    8. How to Descale a Breville Barista Pro BES878-RVC: étape 8, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 8, image 2 de 2
      • Press down on the “Filter Size” knob to select descale.
      • The letter d will appear on the display and the one cup button will illuminate.
      Demander à FixBot
    9. How to Descale a Breville Barista Pro BES878-RVC: étape 9, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 9, image 2 de 2
      • Press the one cup button to enter descale mode.
      • d3 will appear on the display and water will pour from the group head.
      Demander à FixBot
    10. How to Descale a Breville Barista Pro BES878-RVC: étape 10, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 10, image 2 de 2
      • Wait for the display to show “d2.”
      • Rotate the right dial to the hot water icon to descale the hot water dispenser.
      Demander à FixBot
    11. How to Descale a Breville Barista Pro BES878-RVC: étape 11, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 11, image 2 de 2
      • Wait for the display to show “d1.”
      • Rotate the right dial to the steam icon to descale the steam wand.
      Demander à FixBot
    12. How to Descale a Breville Barista Pro BES878-RVC: étape 12, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 12, image 2 de 2
      • Wait for the display to show “r.”
      • Rotate the right dial back to the neutral position.
      • r means "rinse." You are now in the rinsing phase of descaling your espresso machine.
      Demander à FixBot
    13. How to Descale a Breville Barista Pro BES878-RVC: étape 13, image 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 13, image 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 13, image 3 de 3
      • Pull out and empty the water tank.
      • Fill the water tank with fresh water to the max line.
      • Reinsert the water tank.
      Demander à FixBot
    14. How to Descale a Breville Barista Pro BES878-RVC: étape 14, image 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 14, image 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 14, image 3 de 3
      • Pull out the drip tray.
      • Empty the drip tray.
      • Reinsert the drip tray.
      Demander à FixBot
    15. How to Descale a Breville Barista Pro BES878-RVC: étape 15, image 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 15, image 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 15, image 3 de 3
      • Press the one cup button to initiate the rinse cycle.
      • “r3” should appear on the display.
      • Wait for the display to show “r2”.
      • Rotate the right dial to the hot water icon to rinse the hot water dispenser.
      Demander à FixBot
    16. How to Descale a Breville Barista Pro BES878-RVC: étape 16, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 16, image 2 de 2
      • Wait for the display to show “r1.”
      • Rotate the right dial to the steam icon to rinse the steam wand.
      Demander à FixBot
    17. How to Descale a Breville Barista Pro BES878-RVC: étape 17, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 17, image 2 de 2
      • Once the rinse is complete, the grind amount option will appear on the display.
      Demander à FixBot
    18. How to Descale a Breville Barista Pro BES878-RVC: étape 18, image 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 18, image 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: étape 18, image 3 de 3
      • Pull out the water tank.
      • Reinsert the water filter.
      • Refill the water tank with fresh water.
      Demander à FixBot
    19. How to Descale a Breville Barista Pro BES878-RVC: étape 19, image 1 de 1
      • Pull out and empty the drip tray.
      Demander à FixBot
    20. How to Descale a Breville Barista Pro BES878-RVC: étape 20, image 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: étape 20, image 2 de 2
      • Reinsert the water tank and drip tray.
      • Your expresso machine should be clean and produce better tasting drinks!
      Demander à FixBot
Ligne d'arrivée
Jeffery Huang
Membre depuis le 09/07/23
301 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-14, O'Regan Fall 2023 Membre de l'équipe York University, Team 1-14, O'Regan Fall 2023
YORK-O'REGAN-F23S1G14
1 membre
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 56
30 derniers jours : 174
Total : 6,599
