Aller au contenu principal
Introduction
The Auto Boot feature powers on your laptop as soon as you open the lid, so it must be disabled before undertaking certain repairs. Auto Boot can be found on 2016 (and newer) MacBook Pros and 2017 (and newer) 12" Retina MacBooks.
This guide will walk you through the process of disabling Auto Boot, and then re-enabling it when your repair is complete.
  1. Power on your Mac and launch Terminal. To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon. To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
    • Power on your Mac and launch Terminal.
    • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
  2. Copy and paste the following command (or type it exactly) into Terminal: sudo nvram AutoBoot=%00
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return].
    • Your [return] key may also be labeled ⏎ or [enter].
    • If you are prompted for an administrative password, type the password and press [return].
    • Your password will not be displayed in Terminal.
  3. You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • Remember, you must still disconnect the battery before servicing internal components.
  4. When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature. Power on your Mac and launch Terminal. Copy and paste the following command (or type it exactly) into Terminal:
    • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
    • sudo nvram AutoBoot=%03
    • Press [return].
    • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
Congrats! You're done.
7 autre(s) ont terminé cette réparation.
Jeff Suovanen
Membre depuis le 06/08/2013
257 122 Réputation
216 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
9 591 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 12
7 derniers jours : 131
30 derniers jours : 567
Total : 6,911
