Introduction
If you find that your OXO POP storage container is jammed or needs a deep cleaning, use this guide to disassemble your container's lid for a thorough cleaning.
If the button on the lid seems to be stuck, then disassembling the lid will restore the lid to its original functionality. Be cautious that inside the lid, there is a spring that might release unexpectedly during the fix. Keep a distance to prevent any injuries. The reassembly process begins in step 4.
Ce dont vous avez besoin
Twist the bottom piece off by following the directions displayed on the lid.
Once inside, remove the outer layer seal from the lid by pulling it straight up.
After separating the prongs, the spring and the circular spring cap will separate from the square frame with little force.
With some force, remove the two prongs from the base of the lid by snapping them out of the bracket. Be careful not to break the bracket's small prongs.
The disassembled parts can now be cleaned with warm, soapy water.
2 autres ont terminé cette réparation.
Un commentaire
Excellent guide, a set I got came with the metal pins of the prongs unseated from their holes, causing the lid to operate incorrectly. I was able to re-seat them and get the lid working with the help of this.
