Aller au contenu principal
How to Disconnect an iPad Battery with a Playing Card
Ce dont vous avez besoin
  1. How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: étape 1, image 1 de 2 How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: étape 1, image 2 de 2
    • Line up the left edge of a playing card with the left edge of the battery connector.
    • Use a pen to mark both sides of the screw hole and the end of the battery connector as shown.
  2. How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: étape 2, image 1 de 2 How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: étape 2, image 2 de 2
    • Line up the top edge of the card with the top edge of the screw hole.
    • Use a pen to mark the bottom edge of the battery connector.
    • These markings will aid in cutting a slot in the card to clear the screw hole.
  3. How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: étape 3, image 1 de 2 How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: étape 3, image 2 de 2
    • The length of the battery blocker is not important, but we recommend it to be about an inch, or the length from the tip of your thumb to its knuckle.
    • Use a pair of scissors to cut out the playing card battery blocker as shown.
  4. How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: étape 4, image 1 de 3 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: étape 4, image 2 de 3 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: étape 4, image 3 de 3
    • Be extremely slow and careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Insert the battery blocker at a 35 degree angle to disconnect the battery.
    • The playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
9 autres ont terminé cette réparation.
Robert Boyd
Membre depuis le 02/01/21
27 179 Réputation
94 tutoriels rédigés
Un commentaire
Thanks Robert. Great easy to create tool and excellent explanation.
Kevin Stark - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 81
30 derniers jours : 284
Total : 9,739
