Aller au contenu principal
How to Fix A Crooked Cabinet Door
Ce dont vous avez besoin
  1. How to Fix A Crooked Cabinet Door, How to Fix A Crooked Cabinet Door: étape 1, image 1 de 1
    • Open the cabinet door, and determine where it is misaligned.
  2. How to Fix A Crooked Cabinet Door: étape 2, image 1 de 1
    • Re-attach the hinge into place.
    • Soft-closing multi-adjustable hinges can snap back into their thickness plates which is the part attached to the inside of the cabinet.
    • Avoid placing your fingers near the thickness plate as its force can cause a painful pinch.
  3. How to Fix A Crooked Cabinet Door: étape 3, image 1 de 1
    • Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
    • There are different methods for aligning your cabinet door depending on the screw you tighten and the direction:
    • Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
    • Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
  4. How to Fix A Crooked Cabinet Door: étape 4, image 1 de 1
    • The result of the tightened hinge will look as pictured.
  5. How to Fix A Crooked Cabinet Door: étape 5, image 1 de 1
    • Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
    • The result should look as pictured.
Ligne d'arrivée
Camrynne Paul
Membre depuis le 03/19/22
121 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-44, Briggs Spring 2022 Membre de l'équipe CSU Los Angeles, Team 4-44, Briggs Spring 2022
CSULA-BRIGGS-S22S4G44
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 73
30 derniers jours : 288
Total : 7,346
