Aller au contenu principal
How to Fix A Stripped Screw Hole
Ce dont vous avez besoin
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: étape 1, image 1 de 1
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: étape 2, image 1 de 2 How to Fix A Stripped Screw Hole: étape 2, image 2 de 2
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: étape 3, image 1 de 2 How to Fix A Stripped Screw Hole: étape 3, image 2 de 2
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: étape 4, image 1 de 1
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: étape 5, image 1 de 1
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: étape 6, image 1 de 2 How to Fix A Stripped Screw Hole: étape 6, image 2 de 2
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Your screw should now hold secure.
Isaiah Valdez Mireles
Membre depuis le 08/22/22
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 3-24, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 3-24, Briggs Fall 2022
CSULA-BRIGGS-F22S3G24
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 55
Total : 1,537
