Introduction
These are the preliminary steps that are often useful when you think about repairing something.
Try to describe what your device is doing and what instead you expect it to do.
If it is not obvious, check if the behaviour is actually a problem or not.
Pro tip: even if this is the intended behaviour, you are entitled to modify it, if you like. Just it's not "fixing" anymore: that's hacking!
Did you forget to put the plug in the socket? Did you check the battery? Is the light bulb burn out?
In Europe, everything has two years of warranty by law. Do not give up your rights!
There is a very good chance that you will find something useful with a little search online.
Speak with friends, family or collegues. Even if they don't know anything, speaking helps a lot the reasoning.
Speak to a rubber duck
Take a minute to think if there is anything that could be a safety hazard.
Check the user manual and the package, if available, and the device itself for any danger label.
You are now ready to repair your stuff!
8 autres ont terminé cette réparation.
