Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Fix Bicycle Foam Handlebar Grips
Ce dont vous avez besoin
  1. How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: étape 1, image 1 de 3 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: étape 1, image 2 de 3 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: étape 1, image 3 de 3
    • Assess the problem area on your bike's handlebars.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Fix Bicycle Foam Handlebar Grips: étape 2, image 1 de 2 How to Fix Bicycle Foam Handlebar Grips: étape 2, image 2 de 2
    • Lightly sand down the handlebar with the sandpaper.
    • Continue to sand the handlebar until no more residue falls.
    Demander à FixBot
  3. How to Fix Bicycle Foam Handlebar Grips: étape 3, image 1 de 2 How to Fix Bicycle Foam Handlebar Grips: étape 3, image 2 de 2
    • Boil water in a pot.
    • Once the water reaches boiling temperature (212°F/100°C), dip a rag into the water.
    • Be careful when handling the rag after it has been taken out of the boiling water. Handling the rag too quickly can result in a burn.
    • Take the soaked rag and begin cleaning the handlebar by applying pressure and rubbing in a downwards motion.
    Demander à FixBot
  4. How to Fix Bicycle Foam Handlebar Grips: étape 4, image 1 de 2 How to Fix Bicycle Foam Handlebar Grips: étape 4, image 2 de 2
    • Press a new, clean rag tightly to the opening of the alcohol bottle.
    • Tip the bottle upside down quickly and soak the rag with the alcohol.
    • Once the rag is soaked, start cleaning the handlebar again. Continue to clean the handlebar until there is no more visible residue coming off.
    Demander à FixBot
  5. How to Fix Bicycle Foam Handlebar Grips: étape 5, image 1 de 2 How to Fix Bicycle Foam Handlebar Grips: étape 5, image 2 de 2
    • Finally, bring the water to a boil once more.
    • Dip a rag into the water and begin rubbing the handlebar for the last time. Clean vigorously until the handlebar is noticeably smoother and no longer crumbling with residue.
    Demander à FixBot
Following these steps should result in handlebars that feel brand new!
3 autres ont terminé cette réparation.
Katy Haas
Membre depuis le 04/28/17
125 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S1-G1, Coad Spring 2017 Membre de l'équipe UC Davis, Team S1-G1, Coad Spring 2017
UCD-COAD-S17S1G1
4 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 65
Total : 6,433
