Introduction
This guide will walk you through removing old or deteriorated treads and risers from a set of stairs. It will also teach you how to bring your stairs back to life by replacing them with new weather treated wood pieces. There are only 11 required steps to this guide which makes it not only cost effective but also time efficient. This fix will allow you to be a part of a community that fixes things instead of contributing to our throwaway economy and causing havoc on our environment. It is important to focus on safety throughout this fix because there will be power tools and manual labor involved.
Ce dont vous avez besoin
Use a pry bar to remove the pre-existing damaged wood pieces.
Start with the riser first.
To reassemble your old stairs, follow these instructions in reverse order.
