Introduction
Hello, In this guide, I will demonstrate how to repair cracked drywall by reinforcing the crack, sanding the wall, and painting it with some base paint so you can paint the spot to match the surrounding area. You will need a few tools such as a putty knife, a paint pan, and a box cutter, to name a few.
Be diligent when handling a box cutter, as it can cut and possibly sever a finger when not used cautiously.
This repair may prevent further damage to the structure, prevent pests from entering the home, and allow easy access. Fixing drywall may seem intimidating at first, but you will be a professional by the end of this guide.
Ce dont vous avez besoin
Before getting started, clear the area and make sure all remaining objects such as furniture are covered so they will not get dusty.
Now apply the putty to the affected areas. Press the putty into the crack you widened. That will allow the putty to go in the gap and reinforce the drywall.
Use an up and down motion covering the crack on the drywall if it's horizontal. You may also need to move your hand left to right if it's vertical.
With the sandpaper wrapping the block, sand off any excess putty or bumps caused by the putty; this is good for when you want to paint over the area covered by the putty and create an even surface.
When sanding, you will want to go in a circular motion (clockwise or counter-clockwise) or go vertically and horizontally. Check if the surface is even.
By the end of this guide, you will have fixed a drywall crack, sanded it, and painted it using base paint to prepare for the final paint.
3 autres ont terminé cette réparation.
