Aller au contenu principal
How to Fix Sticky Controls on a Logitech RumblePad2
Ce dont vous avez besoin
  1. How to Fix Sticky Controls on a Logitech RumblePad2, How to Fix Sticky Controls on a Logitech RumblePad2: étape 1, image 1 de 1
    • Remove the battery pack cover.
    • Remove the batteries.
  2. How to Fix Sticky Controls on a Logitech RumblePad2: étape 2, image 1 de 1
    • Remove the five screws from the back of the controller using the #0 Phillips screwdriver.
  3. How to Fix Sticky Controls on a Logitech RumblePad2: étape 3, image 1 de 2 How to Fix Sticky Controls on a Logitech RumblePad2: étape 3, image 2 de 2
    • Remove the back panel from the controller.
    • It is easiest to first pry off the panel from the bottom, as shown in the pictures.
    • If using a tool to pry the panel off, do not insert the tool far into the controller. This may damage the motherboard.
  4. How to Fix Sticky Controls on a Logitech RumblePad2: étape 4, image 1 de 1
    • Remove the two screws from the motherboard using the #0 Phillips screwdriver.
  5. How to Fix Sticky Controls on a Logitech RumblePad2: étape 5, image 1 de 2 How to Fix Sticky Controls on a Logitech RumblePad2: étape 5, image 2 de 2
    • Remove the rumble motors from their slots and allow them to hang freely.
    • Remove the motherboard from the controller by lifting up.
  6. How to Fix Sticky Controls on a Logitech RumblePad2: étape 6, image 1 de 1
    • Wipe the outer face of the analog sticks with a wet cotton swab or paper towel.
  7. How to Fix Sticky Controls on a Logitech RumblePad2: étape 7, image 1 de 1
    • Wipe the button pads with a wet cotton swab or paper towel.
  8. How to Fix Sticky Controls on a Logitech RumblePad2: étape 8, image 1 de 2 How to Fix Sticky Controls on a Logitech RumblePad2: étape 8, image 2 de 2
    • Remove the buttons from their slots by pushing them in from the front.
    • Wipe the buttons with a wet cotton swab or paper towel
After allowing the controller time to dry, reassemble your device by following these instructions in reverse order.
Dan Heckman
Membre depuis le 10/05/17
101 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team S3-G11, Galliah Fall 2017 Membre de l'équipe Michigan Tech, Team S3-G11, Galliah Fall 2017
MTU-GALLIAH-F17S3G11
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 1,048
