Introduction
Oh no! Your glasses got warped and bent out of shape! If you wear acetate eyeglasses, this guide can help you repair them into working order. Eyeglasses can be expensive to replace, so making sure that you're able to repair them can save you some money. Using a microfiber cloth, your hands, and some warm water, you'll be able to save your glasses and get them looking good as new.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Microfiber Cleaning Cloths$3.99
Place the microfiber cloth on a table or flat surface and remove lenses from the frame.
To remove the lenses, use both hands to hold the frame. Have one hand on top of the frame to secure it, and have your other hand on the bottom with your thumb pressed against the inside/face side of the lens.
While securely holding the frame, pinch the frame and push the lens out using your thumb.
Place the removed lens onto the microfiber cloth.
Reinsert lenses back into the frame.
To reinsert your lenses, place one hand at the top of the frame where you are inserting the lens.
Place the lens into the groove of the frame, holding it down with your thumb.
Press the lens along the edge of the frame, and the lens will pop back into the frame.
