Aller au contenu principal
How to Fix Warped LEGO Baseplates
Ce dont vous avez besoin
  1. How to Fix Warped LEGO Baseplates, How to Fix Warped LEGO Baseplates: étape 1, image 1 de 1
    • Grab a pot large enough to place the LEGO baseplate in.
    • Fill the pot full of tap water, enough to submerge the baseplate completely.
  2. How to Fix Warped LEGO Baseplates: étape 2, image 1 de 3 How to Fix Warped LEGO Baseplates: étape 2, image 2 de 3 How to Fix Warped LEGO Baseplates: étape 2, image 3 de 3
    • Place the pot of water on a stove.
    • Turn the stove burner on to medium heat.
    • Heat the water to approximately 100 degrees Fahrenheit. Use a thermometer to ensure proper heat.
    • Do not heat water near or above a temperature of 140 degrees Fahrenheit to avoid damaging/melting the plastic.
  3. How to Fix Warped LEGO Baseplates: étape 3, image 1 de 3 How to Fix Warped LEGO Baseplates: étape 3, image 2 de 3 How to Fix Warped LEGO Baseplates: étape 3, image 3 de 3
    • Place the LEGO baseplate in the pot of heated water for 5-7 minutes.
    • Ensure that the LEGO baseplate is fully submerged for the entire heating duration.
  4. How to Fix Warped LEGO Baseplates: étape 4, image 1 de 1
    • Turn the stove off and remove the baseplate from the water.
    • Dry the LEGO baseplate using a paper towel.
  5. How to Fix Warped LEGO Baseplates: étape 5, image 1 de 1
    • Quickly sandwich the baseplate between two flat baking pans while the baseplate is still warm.
    • You can use any two flat, sturdy objects if baking pans are unavailable.
  6. How to Fix Warped LEGO Baseplates: étape 6, image 1 de 2 How to Fix Warped LEGO Baseplates: étape 6, image 2 de 2
    • Place two plastic clamps over the two pans to evenly apply firm pressure against the baseplate.
    • If clamps are unavailable, you can use weights to apply similar pressure.
    • Leave the LEGO baseplate in between the pressure of the baking pans for at least 5 hours.
If your LEGO baseplate is still warped after the 5 hours of sitting in between the clamps, repeat process and leave the LEGO baseplate in between clamps for an additional 5 hours.
2 autres ont terminé cette réparation.
Nicole DeFer
Membre depuis le 09/26/22
203 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team 1-5, Bruce Fall 2022 Membre de l'équipe CSU Fullerton, Team 1-5, Bruce Fall 2022
CSUF-BRUCE-F22S1G5
2 membres
2 tutoriels rédigés
Un commentaire
100 degrees doesn't seem hot enough.
michael kithcart - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 40
30 derniers jours : 103
Total : 2,331
