Introduction
Growing up, I have always played Xbox, and one problem that I've consistently had has to do with the joysticks of the controllers. The problem that I experience the most is referred to as a drift stick, which is when your character in the game moves or looks around when you're not touching the controller. This can become extremely frustrating in first and third person video games, and make it difficult to play well. I decided to create this guide to help others running into the same issue. Fixing the problem doesn't take long, and you only need 70% isopropyl alcohol, and a few cotton balls.
Ce dont vous avez besoin
Remove the batteries from the controller.
After fixing the controller, if there are any more problems, later on, repeat the same process to have it working again.
11 autres ont terminé cette réparation.
10 commentaires
Personally wouldn't recommend using hand sanitizer. IPA of various concentrations is already cheap and readily available in every pharmacy section, or a can of WD-40 Specialist Contact Cleaner is also around $5. In theory, hand sanitizer would "work" if it's ethanol/isopropyl alcohol based, but there's such a broad range of hand sanitizers, it would be irresponsible to make a blanket statement that they're all safe/unsafe for electronics. For example, many brands include fragrances, moisturizers, vitamin-E, etc. to keep your hands from excessively drying out, which can end up leaving residue and gumming up your electronics' contacts further.
I had actually been dumb enough not to look this up, so I just replaced the thumb sticks and it had made it better, but it didn't fix it. Any recommendations? I've had the controller since around 2016 or 2017. Original controller that came with the xbox.
The original Xbox one controller is notorious for getting stick drift. Only way to fix that one is the re-Solder the thumb stick back on. Like remove it and re-solder it.
THANK YOU!!!! Bruh….thank you.
