Aller au contenu principal
How to Fix a Broken XLR Microphone Cable
Ce dont vous avez besoin
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: étape 1, image 1 de 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: étape 1, image 2 de 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: étape 1, image 3 de 3
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: étape 2, image 1 de 1
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: étape 3, image 1 de 2 How to Fix a Broken XLR Microphone Cable: étape 3, image 2 de 2
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: étape 4, image 1 de 3 How to Fix a Broken XLR Microphone Cable: étape 4, image 2 de 3 How to Fix a Broken XLR Microphone Cable: étape 4, image 3 de 3
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: étape 5, image 1 de 2 How to Fix a Broken XLR Microphone Cable: étape 5, image 2 de 2
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
4 autres ont terminé cette réparation.
Abbie Zajac
Membre depuis le 01/19/16
203 Réputation
1 tutoriel rédigé
Équipe
Oakland University, Team 6-3, Walwema Winter 2016 Membre de l'équipe Oakland University, Team 6-3, Walwema Winter 2016
OAK-WALWEMA-W16S6G3
2 membres
2 tutoriels rédigés
Un commentaire
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 152
Total : 25,024
