Aller au contenu principal
How to Fix a Chair Armrest
Ce dont vous avez besoin
  1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: étape 1, image 1 de 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: étape 1, image 2 de 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: étape 1, image 3 de 3
    • Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
    • You can also use a screwdriver instead of a drill.
  2. How to Fix a Chair Armrest: étape 2, image 1 de 2 How to Fix a Chair Armrest: étape 2, image 2 de 2
    • This is the chair that we will fix, and the armrest that was broken.
  3. How to Fix a Chair Armrest: étape 3, image 1 de 2 How to Fix a Chair Armrest: étape 3, image 2 de 2
    • Sand just the inside tip of the armrest as shown.
  4. How to Fix a Chair Armrest: étape 4, image 1 de 2 How to Fix a Chair Armrest: étape 4, image 2 de 2
    • Apply a little bit of glue on the part that you sanded.
    • It is fine if you do not want to use glue.
  5. How to Fix a Chair Armrest: étape 5, image 1 de 2 How to Fix a Chair Armrest: étape 5, image 2 de 2
    • Put the screw washer on the screw.
  6. How to Fix a Chair Armrest: étape 6, image 1 de 3 How to Fix a Chair Armrest: étape 6, image 2 de 3 How to Fix a Chair Armrest: étape 6, image 3 de 3
    • Insert the screw inside the hole on the inside of the chair body.
    • Have another person attach the armrest and then screw it with your hand.
  7. How to Fix a Chair Armrest: étape 7, image 1 de 2 How to Fix a Chair Armrest: étape 7, image 2 de 2
    • Insert the screw into the end of the armrest, attaching it to the edge of the back of the chair using a drill.
    • You may also use a screwdriver instead of a drill.
  8. How to Fix a Chair Armrest: étape 8, image 1 de 3 How to Fix a Chair Armrest: étape 8, image 2 de 3 How to Fix a Chair Armrest: étape 8, image 3 de 3
    • Tighten up the screw with a hex wrench screwdriver.
  9. How to Fix a Chair Armrest: étape 9, image 1 de 2 How to Fix a Chair Armrest: étape 9, image 2 de 2
    • All done! Now your armrest should feel securely attached to the chair.
These are moderate step to fix your chair armrest.
Deviny
Membre depuis le 03/23/21
196 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G2, O'Connell Spring 2021 Membre de l'équipe UMass Dartmouth, Team S1-G2, O'Connell Spring 2021
UMASSD-O'CONNELL-S21S1G2
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 61
Total : 2,571
