Aller au contenu principal
How to Fix a Flexi Leash
Ce dont vous avez besoin
Vidéo d'introduction
  1. How to Fix a Flexi Leash, How to Fix a Flexi Leash: étape 1, image 1 de 1
    • Place the object in a clear bright space.
  2. How to Fix a Flexi Leash: étape 2, image 1 de 3 How to Fix a Flexi Leash: étape 2, image 2 de 3 How to Fix a Flexi Leash: étape 2, image 3 de 3
    • Start by removing all the 0.5 cm screws off the leash with the Phillips #0 screwdriver.
  3. How to Fix a Flexi Leash: étape 3, image 1 de 3 How to Fix a Flexi Leash: étape 3, image 2 de 3 How to Fix a Flexi Leash: étape 3, image 3 de 3
    • Using a plastic opening tool, begin to separate the top and bottom of the leash.
    • Make sure to press lightly to prevent unwanted marks.
    • It is most likely that the brake button will fall out. Place small items to the side to prevent it from being lost or undetected.
  4. How to Fix a Flexi Leash: étape 4, image 1 de 2 How to Fix a Flexi Leash: étape 4, image 2 de 2
    • Carefully remove the brake mechanism. Inside should be a small spring.
    • Remove and replace the spring with a new one.
    • When placing the break mechanism back into its place, make sure the spring is positioned right in the middle.
  5. How to Fix a Flexi Leash: étape 5, image 1 de 3 How to Fix a Flexi Leash: étape 5, image 2 de 3 How to Fix a Flexi Leash: étape 5, image 3 de 3
    • When the spring is successfully placed, initiate the retraction to it's original position.
    • Make sure the top and the bottom are aligned properly.
    • Slowly press the top and the bottom of the leash until it returns to its initial position.
  6. How to Fix a Flexi Leash: étape 6, image 1 de 3 How to Fix a Flexi Leash: étape 6, image 2 de 3 How to Fix a Flexi Leash: étape 6, image 3 de 3
    • Finish by screwing the 0.5 cm screws in their original position.
Ligne d'arrivée
Joanette M. Anton Cordero
Membre depuis le 10/06/21
133 Réputation
1 tutoriel rédigé
Un commentaire
Where do i buy the spring?
Andrew Storeck - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 102
Total : 4,156
