Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Fix a Hole in a Pant Pocket
Ce dont vous avez besoin
  1. How to Fix a Hole in a Pant Pocket, Prepare trousers: étape 1, image 1 de 3 How to Fix a Hole in a Pant Pocket, Prepare trousers: étape 1, image 2 de 3 How to Fix a Hole in a Pant Pocket, Prepare trousers: étape 1, image 3 de 3
    • Turn the trousers inside out and place them taut and flat on an ironing board.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Fix a Hole in a Pant Pocket, Prepare patch: étape 2, image 1 de 3 How to Fix a Hole in a Pant Pocket, Prepare patch: étape 2, image 2 de 3 How to Fix a Hole in a Pant Pocket, Prepare patch: étape 2, image 3 de 3
    • Bring the patch into the right shape by folding it in half so that you can place it around your trouser pocket as desired.
    Demander à FixBot
  3. How to Fix a Hole in a Pant Pocket, Iron on the first half of the patch: étape 3, image 1 de 2 How to Fix a Hole in a Pant Pocket, Iron on the first half of the patch: étape 3, image 2 de 2
    • Place the patch fabric between your trouser leg and pocket. The side of the patch with the iron-on patch facing the pocket.
    • Position the patch so that one half of the patch is under the trouser pocket and the other half is free next to it.
    • Iron the part of the patch under the pocket firmly to the back of the pocket by pressing the iron onto the pocket and the patch underneath.
    • When ironing, do not touch the free half of the patch with the iron.
    • If necessary, follow the manufacturer's instructions regarding the use of a cloth or the steam function of your iron.
    Demander à FixBot
  4. How to Fix a Hole in a Pant Pocket, Iron the patch completely: étape 4, image 1 de 2 How to Fix a Hole in a Pant Pocket, Iron the patch completely: étape 4, image 2 de 2
    • Now fold the free half of the patch over the trouser pocket so that it lies flush with the other half. The trouser pocket itself is now sandwiched between the two patch halves.
    • Now iron the patch onto the front of the pocket, applying sufficient pressure.
    • Tip: If necessary, iron the separately stretched out trouser pocket again from the other side so that the patch adheres properly to both sides of the trouser pocket.
    Demander à FixBot
  5. How to Fix a Hole in a Pant Pocket, Sew patches onto trouser pockets: étape 5, image 1 de 3 How to Fix a Hole in a Pant Pocket, Sew patches onto trouser pockets: étape 5, image 2 de 3 How to Fix a Hole in a Pant Pocket, Sew patches onto trouser pockets: étape 5, image 3 de 3
    • Now sew the patch to the pocket. Follow the contour of the pocket, but let the seam run within the contour so that the patch is connected to the pocket.
    • Use a stitch that ensures a good and strong connection between the pocket and the patch fabric.
    Demander à FixBot
  6. How to Fix a Hole in a Pant Pocket, If necessary, sew a second seam: étape 6, image 1 de 1
    • In order to firmly connect the patch and the trouser pocket, a second, slightly offset seam may be useful.
    Demander à FixBot
  7. How to Fix a Hole in a Pant Pocket, Remove fabric remnants: étape 7, image 1 de 1
    • Cut off any excess fabric outside the pocket contour with scissors.
    Demander à FixBot
  8. How to Fix a Hole in a Pant Pocket, Sew edges: étape 8, image 1 de 1
    • Finally, sew the edge of the cut edge with an appropriate stitch (e.g. overlock stitch) to prevent the patch from fraying in the future and to achieve a visually attractive finish to the sewing work.
    Demander à FixBot
    • To further improve the stability and strength of the trouser pocket, you can sew the surface of the trouser pocket to the surface of the patch - on the front and back side of the pocket.
    • Be careful not to sew up the trouser pocket.
    • You can only use a sewing machine here if you can pull the trouser pocket over the extension table or stitch plate. Otherwise, you must perform this step manually with a sewing needle.
    Demander à FixBot
Note: Instead of an ironing board, you can also use a table with a hand towel or bath towel on top.
Merci à ces traducteurs :
de en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
BluRay
Membre depuis le 06/14/24
489 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 48
30 derniers jours : 263
Total : 1,458
