Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Fix a Leaking Garbage Disposal at Flange
Vues: 8,7 k
Afficher les statistiques :
Dernières 24 heures :
3
Sept derniers jours :
18
Trente derniers jours :
141
Total :
8 705
Commentaires: 1
1 commentaire de tutoriel.
Aller aux commentaires de tutoriel
Terminé: 1
1 personne a marqué ce tutoriel comme « terminé ». Serez-vous la prochaine ?
Favoris: 2
2 personnes ont mis ce tutoriel en favori (et s'y sont abonnées). Serez-vous la prochaine ?
Temps nécessaire: 45 minutes
Difficulté: Modérée
Water damage is one of the most difficult disasters to deal with. A leaking sink can flood your cabinets, create mold, and cause thousands of dollars of damage. I have prepared a relatively simple and inexpensive fix to repair a leaking garbage disposal without the hassle of calling a plumber and spending a larger amount of money. This fix requires a screwdriver, a hammer or chisel, and Plumber's Putty.
Ce dont vous avez besoin
Outils
    1. How to Fix a Leaking Garbage Disposal at Flange, How to Fix a Leaking Garbage Disposal at Flange: étape 1, image 1 de 2 How to Fix a Leaking Garbage Disposal at Flange, How to Fix a Leaking Garbage Disposal at Flange: étape 1, image 2 de 2
      • Unplug the garbage disposal from the power source.
      • Be sure to place the wall plug in a dry location for the duration of the fix.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Fix a Leaking Garbage Disposal at Flange: étape 2, image 1 de 2 How to Fix a Leaking Garbage Disposal at Flange: étape 2, image 2 de 2
      • Loosen and disconnect the dishwasher drain hose from the garbage disposal unit by loosening the clamp and removing the screws with a flathead screwdriver.
      • Pull the gray tube from the disposal.
      Demander à FixBot
    3. How to Fix a Leaking Garbage Disposal at Flange: étape 3, image 1 de 2 How to Fix a Leaking Garbage Disposal at Flange: étape 3, image 2 de 2
      • Remove the three screws from the flange at the top of the garbage disposal unit. These screws are at the top right above the black disposal box.
      • Disconnect the lock-nut at the flange.
      • Adequate lighting is imperative for this step.
      Demander à FixBot
    4. How to Fix a Leaking Garbage Disposal at Flange: étape 4, image 1 de 2 How to Fix a Leaking Garbage Disposal at Flange: étape 4, image 2 de 2
      • Use the screwdriver to turn the locking ring counter clock-wise, disengaging the drain hose and disposal.
      • You will be able to hear the locking ring come undone after pushing it forcefully to the left.
      • The disposal will drop down—be sure to catch the disposal and place on the bottom of the sink.
      • Move from underneath the sink to the top of the sink.
      Demander à FixBot
    5. How to Fix a Leaking Garbage Disposal at Flange: étape 5, image 1 de 2 How to Fix a Leaking Garbage Disposal at Flange: étape 5, image 2 de 2
      • To remove the flange, push from underneath the sink with one hand and pull it out through the top of the sink with your other hand.
      • Scrape off ALL excess putty from the flange and the sink.
      Demander à FixBot
    6. How to Fix a Leaking Garbage Disposal at Flange: étape 6, image 1 de 3 How to Fix a Leaking Garbage Disposal at Flange: étape 6, image 2 de 3 How to Fix a Leaking Garbage Disposal at Flange: étape 6, image 3 de 3
      • Remove a small ball of putty and roll into a golf ball shape.
      • Roll the putty flat into a snakelike shape, approximately 3/4 inch diameter.
      • Be sure that the putty is long enough to wrap completely around the flange.
      Demander à FixBot
    7. How to Fix a Leaking Garbage Disposal at Flange: étape 7, image 1 de 2 How to Fix a Leaking Garbage Disposal at Flange: étape 7, image 2 de 2
      • Wrap the putty around the flange and place the flange back into the sink.
      • Press down hard into the sink and remove any excess Plumber's Putty.
      Demander à FixBot
    8. How to Fix a Leaking Garbage Disposal at Flange: étape 8, image 1 de 1
      • Reassemble the flange and garbage disposal by reversing these steps.
      • Put a sink stopper in and fill up the sink approximately halfway.
      • Remove the stopper and check underneath the sink to make sure there are no leaks.
      Demander à FixBot
Amy Haren
Membre depuis le 01/19/18
175 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S19-G2, Stewart Spring 2018 Membre de l'équipe USF Sarasota-Manatee, Team S19-G2, Stewart Spring 2018
USFSM-STEWART-S18S19G2
1 membre
12 tutoriels rédigés
How do you stop the flange screws from backing out? Fixed it yesterday and screws were loose already this evening…help…
Mike T - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 141
Total : 8,705
