Aller au contenu principal
How to Fix a Leaning Wooden Gate
Ce dont vous avez besoin
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: étape 1, image 1 de 2 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: étape 1, image 2 de 2
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
  2. How to Fix a Leaning Wooden Gate: étape 2, image 1 de 1
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
  3. How to Fix a Leaning Wooden Gate: étape 3, image 1 de 3 How to Fix a Leaning Wooden Gate: étape 3, image 2 de 3 How to Fix a Leaning Wooden Gate: étape 3, image 3 de 3
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
  4. How to Fix a Leaning Wooden Gate: étape 4, image 1 de 3 How to Fix a Leaning Wooden Gate: étape 4, image 2 de 3 How to Fix a Leaning Wooden Gate: étape 4, image 3 de 3
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
  5. How to Fix a Leaning Wooden Gate: étape 5, image 1 de 2 How to Fix a Leaning Wooden Gate: étape 5, image 2 de 2
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
  6. How to Fix a Leaning Wooden Gate: étape 6, image 1 de 2 How to Fix a Leaning Wooden Gate: étape 6, image 2 de 2
    • Remove the object you placed underneath.
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
TenzinY
Membre depuis le 09/08/23
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team 2-26, O'Regan Fall 2023 Membre de l'équipe York University, Team 2-26, O'Regan Fall 2023
YORK-O'REGAN-F23S2G26
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 464
