Aller au contenu principal
How to Fix a Loose Arm Rest for Office Chair 068-0935-6
Ce dont vous avez besoin
  1. How to Fix a Loose Arm Rest for Office Chair 068-0935-6, How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 1, image 1 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6, How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 1, image 2 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6, How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 1, image 3 de 3
    • Use a hex key to undo all of the M3 x 6 mm alloy steel hex bolts.
    • Turn the hex key in the counter-clockwise direction to unscrew the bolts.
  2. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 2, image 1 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 2, image 2 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 2, image 3 de 3
    • Avoid scratching the chair with the bolts when removing them from the arm rest.
    • Do the same as mentioned in Step 1 to the other bolts.
  3. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 3, image 1 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 3, image 2 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 3, image 3 de 3
    • After removing the arm rest, get a Q-tip and start cleaning the bolt holes.
    • Make sure to thoroughly clean the insides and use a new Q-tip for a new hole.
  4. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 4, image 1 de 2 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 4, image 2 de 2
    • Adjust the arm so that each hole is aligned with the hole where the bolt goes in as shown in the picture.
    • Get help from another person to hold the armrest up so it stays in alignment.
  5. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 5, image 1 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 5, image 2 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 5, image 3 de 3
    • Reassemble the arm rest and place the the bolts back as they were.
    • To tighten the bolts, turn the hex key in a clockwise direction.
  6. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 6, image 1 de 2 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 6, image 2 de 2
    • Tighten the bolts and check to see if they are tight enough.
    • Check the arm rests to see if they are stiff and not wobbly
    • Check each bolt and tighten till the arm rest isn't wobbly.
  7. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 7, image 1 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 7, image 2 de 3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: étape 7, image 3 de 3
    • Repeat Steps 1-6 for the other arm rest.
Celince Kapadia
Membre depuis le 06/30/21
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G12, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S2-G12, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G12
1 membre
1 tutoriel rédigé
2 commentaires
Suppose that the bolt is not hex or phillips or star, but is completely smooth and the fabric is closed with stitching. After removing the caps that cover the holes in the arm there is just a completely smooth bolt or screw with no way to grip or turn it?????
Ray Carpenter - Réponse
At the very least say to put a lot of cotton on the hole so it will tighten the hole up when u put the screw in. And or put a washer on each bolt. What a joke.
adam - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 92
Total : 3,370
