Aller au contenu principal
How to Fix a Loose Connector in an Anivia 1080p Webcam
Ce dont vous avez besoin
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 1, image 1 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 1, image 2 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 1, image 3 de 3
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 2, image 1 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 2, image 2 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 2, image 3 de 3
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 3, image 1 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 3, image 2 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 3, image 3 de 3
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 4, image 1 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 4, image 2 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 4, image 3 de 3
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 5, image 1 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 5, image 2 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 5, image 3 de 3
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 6, image 1 de 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 6, image 2 de 2
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 7, image 1 de 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 7, image 2 de 2
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 8, image 1 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 8, image 2 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 8, image 3 de 3
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 9, image 1 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 9, image 2 de 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: étape 9, image 3 de 3
    • Snap the faceplate covering back into place.
Ligne d'arrivée
Duncan Holloway
Membre depuis le 02/24/21
169 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 53
Total : 878
