Aller au contenu principal
How to Fix a Papasan Chair Base
Ce dont vous avez besoin
  1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: étape 1, image 1 de 2 How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: étape 1, image 2 de 2
    • Remove and save rattan from broken sections.
  2. How to Fix a Papasan Chair Base: étape 2, image 1 de 1
    • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
  3. How to Fix a Papasan Chair Base: étape 3, image 1 de 2 How to Fix a Papasan Chair Base: étape 3, image 2 de 2
    • Glue the split wood pieces together, clamp, and let them dry.
  4. How to Fix a Papasan Chair Base: étape 4, image 1 de 1
    • Nail the thin decorative wood pieces to the larger sections of the frame.
  5. How to Fix a Papasan Chair Base: étape 5, image 1 de 1
    • Screw the circular base and upper to the vertical supports that have become disconnected.
  6. How to Fix a Papasan Chair Base: étape 6, image 1 de 1
    • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
  7. How to Fix a Papasan Chair Base: étape 7, image 1 de 2 How to Fix a Papasan Chair Base: étape 7, image 2 de 2
    • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
Following these steps will restore your papasan chair to working order.
6 autres ont terminé cette réparation.
Cassidy Calcutt
Membre depuis le 03/31/20
289 Réputation
1 tutoriel rédigé
Équipe
3 commentaires
What screw you used? Screw dimensions?
Lourdes Diaz - Réponse
easy peasy…thanks
Katherine Elaine - Réponse
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 75
30 derniers jours : 367
Total : 17,582
