Introduction
This guide is a tutorial on how to reassemble your Rubik's cube if a piece has popped from the tensions. This may happen if the springs become loose. There is an explanation at the end of the guide on how to tighten your tensions so that it doesn't occur as often in the future. You only need a Phillips head screwdriver to adjust the tensions.
Ce dont vous avez besoin
Place your cube down and look for the popped pieces.
Collect all the popped pieces and group the corners and the edges separately.
This simple yet effective fix will help you prevent any future pops in your Rubik's cube. I hope this guide helped you a lot!
3 autres ont terminé cette réparation.
