Aller au contenu principal
How to Fix a Rattling Door
Ce dont vous avez besoin
  1. How to Fix a Rattling Door, How to Fix a Rattling Door: étape 1, image 1 de 3 How to Fix a Rattling Door, How to Fix a Rattling Door: étape 1, image 2 de 3 How to Fix a Rattling Door, How to Fix a Rattling Door: étape 1, image 3 de 3
    • Remove the strike plate on the door by unscrewing the screws that attach it to the door frame.
    • The type of screwdriver you need depends on the type of screws that hold your strike plate in your door.
  2. How to Fix a Rattling Door: étape 2, image 1 de 2 How to Fix a Rattling Door: étape 2, image 2 de 2
    • Take the strike plate and put it in your hand. Using the pliers in your other hand, bend the metal tab toward the flat side of the strike plate.
  3. How to Fix a Rattling Door: étape 3, image 1 de 2 How to Fix a Rattling Door: étape 3, image 2 de 2
    • Place the strike plate back on the door frame and tighten the screws.
Close your door and shake it back and forth to see if it is still loose. Repeat the guide steps as necessary.
2 autres ont terminé cette réparation.
Sara Novell
Membre depuis le 04/08/15
209 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 30-4, Green Spring 2015 Membre de l'équipe Cal Poly, Team 30-4, Green Spring 2015
CPSU-GREEN-S15S30G4
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 22
30 derniers jours : 90
Total : 39,588
