Aller au contenu principal
How to Fix a Ripped Necktie Seam
Ce dont vous avez besoin
  1. How to Fix a Ripped Necktie Seam, Ripped Seam: étape 1, image 1 de 1
    • Iron the area of the necktie that is ripped.
    • Ironing the necktie allows for clean lines and no wrinkles in the fabric.
    • When ironing, be careful not to burn yourself.
  2. How to Fix a Ripped Necktie Seam: étape 2, image 1 de 1
    • Position your tie with ripped seam facing up.
  3. How to Fix a Ripped Necktie Seam: étape 3, image 1 de 1
    • Gather your thread and scissors.
    • Cut to desired length.
    • Make sure your thread matches the color of your tie.
  4. How to Fix a Ripped Necktie Seam: étape 4, image 1 de 2 How to Fix a Ripped Necktie Seam: étape 4, image 2 de 2
    • Gather your cut thread and needle.
    • Loop your thread through the eye of the needle.
    • Pull the thread until it is even on both ends.
    • Be careful of sharp needle.
  5. How to Fix a Ripped Necktie Seam: étape 5, image 1 de 1
    • Tie the end of the thread with a knot.
  6. How to Fix a Ripped Necktie Seam: étape 6, image 1 de 3 How to Fix a Ripped Necktie Seam: étape 6, image 2 de 3 How to Fix a Ripped Necktie Seam: étape 6, image 3 de 3
    • Poke your needle from the inside of the tie.
    • Pull the thread all the way through until it reaches the tied knot.
    • Leave about 1/4 inches from the original hole.
    • Poke your needle from the outside of the tie and pull thread until knot.
    • Be careful of sharp needle going in and out of fabric
  7. How to Fix a Ripped Necktie Seam: étape 7, image 1 de 3 How to Fix a Ripped Necktie Seam: étape 7, image 2 de 3 How to Fix a Ripped Necktie Seam: étape 7, image 3 de 3
    • Repeat the sewing pattern until you reach the end.
    • Make sure your final thread is through the inside of tie.
  8. How to Fix a Ripped Necktie Seam: étape 8, image 1 de 2 How to Fix a Ripped Necktie Seam: étape 8, image 2 de 2
    • Once the entire seam has been sewn, create a loop with the thread.
    • To tie a knot, bring your needle through the loop and pull.
    • Repeat the knot 2-3 more times.
    • Make sure the knot is flat against the fabric.
  9. How to Fix a Ripped Necktie Seam: étape 9, image 1 de 2 How to Fix a Ripped Necktie Seam: étape 9, image 2 de 2
    • Cut off any excess thread.
    • Do not cut too close to knot or it may unravel.
  10. How to Fix a Ripped Necktie Seam: étape 10, image 1 de 1
    • (Optional) Iron over seam for better results.
Beverly Fan
Membre depuis le 02/02/23
181 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-4, Andersen Winter 2023 Membre de l'équipe UC Davis, Team 2-4, Andersen Winter 2023
UCD-ANDERSEN-W23S2G4
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 69
Total : 1,622
