Aller au contenu principal
How to Fix a Ripped Shirt Hem
Ce dont vous avez besoin
  1. How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: étape 1, image 1 de 3 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: étape 1, image 2 de 3 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: étape 1, image 3 de 3
    • Turn your shirt inside out.
    • Find your shirt's ripped hem.
    • If the shirt has any loose strings, trim them.
  2. How to Fix a Ripped Shirt Hem: étape 2, image 1 de 1
    • Iron the area of the shirt where the hem is ripped.
    • If the hem is ripped several inches, you might want to insert sewing pins to keep the fabric in place.
    • It's important to iron because it allows for easier sewing when the shirt stays folded the same way as the non-ripped part of the hem.
    • The iron will be very hot. Be careful as to not burn yourself.
  3. How to Fix a Ripped Shirt Hem: étape 3, image 1 de 1
    • Acquire a sewing needle and thread.
    • Take your thread and loop it through the eye of the needle, the hole at the end of the needle.
    • You'll want the thread to be the same color and shade as the original thread. For visual purposes, I will use red in place of black.
    • The needle is sharp.
  4. How to Fix a Ripped Shirt Hem: étape 4, image 1 de 1
    • Pull the thread through the needle so that there is an equal length on each side of the needle.
    • Tie the end of the thread together by making a knot.
    • Making an additional knot over the first makes it more secure.
  5. How to Fix a Ripped Shirt Hem: étape 5, image 1 de 1
    • Starting on the inside of the shirt, poke the needle through toward the side that is right-side-out.
    • Sew over the original thread for about half an inch to ensure that it's thread won't rip again.
  6. How to Fix a Ripped Shirt Hem: étape 6, image 1 de 1
    • Once the needle and thread is pulled through the side that is right-side-out, you will push it back through as close to the original hole as you can.
    • Doing this will make the visible hem as hidden as possible.
  7. How to Fix a Ripped Shirt Hem: étape 7, image 1 de 3 How to Fix a Ripped Shirt Hem: étape 7, image 2 de 3 How to Fix a Ripped Shirt Hem: étape 7, image 3 de 3
    • When you're back on the inside of the hem, make the next stitch a couple millimeters over and diagonal from the first.
  8. How to Fix a Ripped Shirt Hem: étape 8, image 1 de 2 How to Fix a Ripped Shirt Hem: étape 8, image 2 de 2
    • Continue this pattern so that the inside has diagonal stitches, and the outside has small, staggered dots.
  9. How to Fix a Ripped Shirt Hem: étape 9, image 1 de 3 How to Fix a Ripped Shirt Hem: étape 9, image 2 de 3 How to Fix a Ripped Shirt Hem: étape 9, image 3 de 3
    • Finish sewing the hem. Make sure the last stitch is on the inside of the shirt.
    • Make a knot where you intend for the pattern to stop.
    • It's important to tie the knot as close to the fabric as possible. Doing this secures the stitching.
  10. How to Fix a Ripped Shirt Hem: étape 10, image 1 de 1
    • Cut off excess thread.
Ligne d'arrivée
4 autres ont terminé cette réparation.
Kaitlyn Adams
Membre depuis le 09/29/15
247 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-5, Green Fall 2015 Membre de l'équipe Cal Poly, Team 17-5, Green Fall 2015
CPSU-GREEN-F15S17G5
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 41
Total : 11,505
