Aller au contenu principal
How to Fix a Small Hole in a Sock
Ce dont vous avez besoin
  1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: étape 1, image 1 de 3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: étape 1, image 2 de 3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: étape 1, image 3 de 3
    • Place one end of your thread through the hole of the needle.
    • Wet the end of your thread to make it easier to go through the hole.
    • Pull your thread all the way through and match the ends of the thread together.
    • Tie a knot with the ends of your thread.
    • The needle is sharp. Handle it carefully to prevent poking your fingers or hand.
  2. How to Fix a Small Hole in a Sock: étape 2, image 1 de 2 How to Fix a Small Hole in a Sock: étape 2, image 2 de 2
    • Insert your tennis ball into the sock until it is lined up with the hole in your sock.
  3. How to Fix a Small Hole in a Sock: étape 3, image 1 de 3 How to Fix a Small Hole in a Sock: étape 3, image 2 de 3 How to Fix a Small Hole in a Sock: étape 3, image 3 de 3
    • Insert your needle into the inside of the sock at the edge of the hole no more than half a centimeter away from the edge.
    • Pull the needle all the way through.
    • If the tail of your thread is too long, trim the excess.
  4. How to Fix a Small Hole in a Sock: étape 4, image 1 de 1
    • Insert your needle next to and below where the first insert was.
    • Pull your needle all the way through to create your first stitch.
  5. How to Fix a Small Hole in a Sock: étape 5, image 1 de 2 How to Fix a Small Hole in a Sock: étape 5, image 2 de 2
    • Insert your needle in the opposite side of the hole and pull to create another stitch.
    • Repeat this step, crisscrossing your stitches until you reach the end of the hole.
    • Keep your stitches loose. You will tighten them at the end.
  6. How to Fix a Small Hole in a Sock: étape 6, image 1 de 3 How to Fix a Small Hole in a Sock: étape 6, image 2 de 3 How to Fix a Small Hole in a Sock: étape 6, image 3 de 3
    • Once you reach the end of the hole, carefully pull on your thread to tighten the stitches together.
  7. How to Fix a Small Hole in a Sock: étape 7, image 1 de 2 How to Fix a Small Hole in a Sock: étape 7, image 2 de 2
    • To close off the stitch, insert your needle back under all of your stitches and pull out your needle at the top of the repair.
    • Pull your needle through, but not all the way, to create a small loop.
  8. How to Fix a Small Hole in a Sock: étape 8, image 1 de 2 How to Fix a Small Hole in a Sock: étape 8, image 2 de 2
    • Insert the needle through the small loop.
    • Pull your needle until the loop disappears.
  9. How to Fix a Small Hole in a Sock: étape 9, image 1 de 2 How to Fix a Small Hole in a Sock: étape 9, image 2 de 2
    • To create a final stitch, insert your needle back under all of your stitches.
    • Pull the thread all the way through.
  10. How to Fix a Small Hole in a Sock: étape 10, image 1 de 3 How to Fix a Small Hole in a Sock: étape 10, image 2 de 3 How to Fix a Small Hole in a Sock: étape 10, image 3 de 3
    • Trim off the excess thread.
    • Remove the tennis ball from your sock.
Ligne d'arrivée
3 autres ont terminé cette réparation.
Yuchen Xu
Membre depuis le 02/03/23
223 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 3-2, Andersen Winter 2023 Membre de l'équipe UC Davis, Team 3-2, Andersen Winter 2023
UCD-ANDERSEN-W23S3G2
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 54
Total : 1,201
