Aller au contenu principal
How to Fix a Sticking Deadbolt
Ce dont vous avez besoin
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: étape 1, image 1 de 2 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: étape 2, image 1 de 2 How to Fix a Sticking Deadbolt: étape 2, image 2 de 2
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: étape 3, image 1 de 1
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: étape 4, image 1 de 2 How to Fix a Sticking Deadbolt: étape 4, image 2 de 2
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: étape 5, image 1 de 1
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: étape 6, image 1 de 2 How to Fix a Sticking Deadbolt: étape 6, image 2 de 2
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: étape 7, image 1 de 2 How to Fix a Sticking Deadbolt: étape 7, image 2 de 2
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: étape 8, image 1 de 1
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: étape 9, image 1 de 3 How to Fix a Sticking Deadbolt: étape 9, image 2 de 3 How to Fix a Sticking Deadbolt: étape 9, image 3 de 3
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: étape 10, image 1 de 1
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
After following this fast fix guide, the sticking deadbolt should be fixed.
5 autres ont terminé cette réparation.
Elizabeth Nesler
Membre depuis le 02/23/16
214 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team 22-5, Rauch Spring 2016 Membre de l'équipe Texas Tech, Team 22-5, Rauch Spring 2016
TTU-RAUCH-S16S22G5
3 membres
1 tutoriel rédigé
Un commentaire
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 115
Total : 39,332
