Introduction
At some point while cleaning your Nama J2 Juicer, you realize that you aren't able to disassemble it because a part is stuck. This piece is most likely the auger.
In search of a quick fix, the directions you lookup tell you to reverse it, put it in the fridge and even soak it for a few hours. But alas - none of these directions are working or take too long.
This guide will show you how to remove a stuck auger for your Nama J2 Juicer in a fast, efficient and easy way!
Find a tool with a small handle that fits in the space under the auger.
