Aller au contenu principal
How to Fix a Stuck Trombone Tuning Slide
Ce dont vous avez besoin
  1. How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: étape 1, image 1 de 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: étape 1, image 2 de 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: étape 1, image 3 de 3
    • Carefully remove the slides from the trombone.
    • If the slides are completely stuck, wiggle the slides from side to side while pulling it out of the trombone.
  2. How to Fix a Stuck Trombone Tuning Slide: étape 2, image 1 de 1
    • Clean each slide using a paper towel or cloth.
    • This will remove any friction the slides may have with the trombone.
  3. How to Fix a Stuck Trombone Tuning Slide: étape 3, image 1 de 1
    • Check to see if the tuning slides are parallel with their corresponding parts.
    • This can be done simply by aligning the slides against the trombone.
  4. How to Fix a Stuck Trombone Tuning Slide: étape 4, image 1 de 2 How to Fix a Stuck Trombone Tuning Slide: étape 4, image 2 de 2
    • If the slides are parallel, skip to step six. If not, attach each individual slide to the trombone and push/pull in the direction in which it would be parallel.
    • This will straighten the warped slides back into place.
    • Warped slides can be very difficult to move when attached to the trombone.
  5. How to Fix a Stuck Trombone Tuning Slide: étape 5, image 1 de 2 How to Fix a Stuck Trombone Tuning Slide: étape 5, image 2 de 2
    • Check to see if the slides are align once more.
    • Keep repeating step 4 if the slides are not lined up yet.
  6. How to Fix a Stuck Trombone Tuning Slide: étape 6, image 1 de 2 How to Fix a Stuck Trombone Tuning Slide: étape 6, image 2 de 2
    • Apply tuning slide grease to each slide.
    • Make sure each slide only gets a thin layer of grease. Too much grease could cause friction when attached to the trombone.
  7. How to Fix a Stuck Trombone Tuning Slide: étape 7, image 1 de 1
    • Attach the slides back to the trombone.
    • Position the slides to your liking and enjoy playing!
Ligne d'arrivée
Nolan Robinson
Membre depuis le 02/27/18
172 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 2,018
