Aller au contenu principal
How to Fix a T-shirt That's Too Big
Ce dont vous avez besoin
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: étape 1, image 1 de 2 How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: étape 1, image 2 de 2
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: étape 2, image 1 de 1
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: étape 3, image 1 de 1
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: étape 4, image 1 de 1
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: étape 5, image 1 de 1
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: étape 6, image 1 de 1
    • Use scissors to cut any extra threads left over from the project.
Ligne d'arrivée
3 autres ont terminé cette réparation.
lakshay
Membre depuis le 09/26/22
185 Réputation
1 tutoriel rédigé
Équipe
York University, Team A-18, Morris Fall 2022 Membre de l'équipe York University, Team A-18, Morris Fall 2022
YORK-MORRIS-F22SAG18
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 56
Total : 1,668
