Aller au contenu principal
How to Fix a Wobbly Hydraulic Barber Chair
Ce dont vous avez besoin
  1. How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: étape 1, image 1 de 2 How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: étape 1, image 2 de 2
    • The issue with the barber chair is located at the base, where the screws have come loose.
  2. How to Fix a Wobbly Hydraulic Barber Chair: étape 2, image 1 de 2 How to Fix a Wobbly Hydraulic Barber Chair: étape 2, image 2 de 2
    • Use your foot to repeatedly pump the hydraulic height-adjustment pedal under the chair until the chair reaches max height.
    • While holding the pedal down with your foot, grab both arm rests and pull the chair upwards.
  3. How to Fix a Wobbly Hydraulic Barber Chair: étape 3, image 1 de 1
    • Lift the base-ring off the base to reveal the holes for the screws.
  4. How to Fix a Wobbly Hydraulic Barber Chair: étape 4, image 1 de 1
    • Place a screw with a washer attached into a hole and tighten it with a 7/32" hex bit.
    • Repeat this process for the other 5 screws and washers.
  5. How to Fix a Wobbly Hydraulic Barber Chair: étape 5, image 1 de 1
    • Align the bottom of the seat with the top of the pole, and gently put it back into position.
  6. How to Fix a Wobbly Hydraulic Barber Chair: étape 6, image 1 de 1
    • Make sure the seat is properly fitted onto the pole by gently pushing down on the seat.
    • Check the stability of the pole by gently shaking the chair.
Gaurav Tiwari
Membre depuis le 01/21/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G28, Melo-Thaiss Winter 2021 Membre de l'équipe York University, Team S1-G28, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G28
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 77
Total : 3,582
