Aller au contenu principal
How to Fix an Air Tech 2K0 Aquarium Pump
Ce dont vous avez besoin
  1. How to Fix an Air Tech 2K0 Aquarium Pump, How to Fix an Air Tech 2K0 Aquarium Pump: étape 1, image 1 de 2 How to Fix an Air Tech 2K0 Aquarium Pump, How to Fix an Air Tech 2K0 Aquarium Pump: étape 1, image 2 de 2
    • Begin disassembling the air pump by removing the screws (2.9mm x 13mm) with the small Philips screwdriver.
  2. How to Fix an Air Tech 2K0 Aquarium Pump: étape 2, image 1 de 2 How to Fix an Air Tech 2K0 Aquarium Pump: étape 2, image 2 de 2
    • Remove the cover of the air pump to expose the inside of it.
    • Set aside the three screws (2.9mm x 13mm) and cover to save for reassembly at the end of the guide.
  3. How to Fix an Air Tech 2K0 Aquarium Pump: étape 3, image 1 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 3, image 2 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 3, image 3 de 3
    • Remove the round, rubber cover called the diaphragm.
  4. How to Fix an Air Tech 2K0 Aquarium Pump: étape 4, image 1 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 4, image 2 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 4, image 3 de 3
    • Once the entire piece is removed, unscrew the the rubber diaphragm from the metal part.
    • Begin by twisting off the washer.
    • From here, remove the metal piece and the screw (1.25mm x 8mm) from the center of the diaphragm.
  5. How to Fix an Air Tech 2K0 Aquarium Pump: étape 5, image 1 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 5, image 2 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 5, image 3 de 3
    • Once the diaphragm has been separated, set aside the metal piece, the screw (1.25mm x 8mm), and the washer.
    • Examine the diaphragm for damage.
    • Here, you can see a hole in the diaphragm that needs to be repaired.
  6. How to Fix an Air Tech 2K0 Aquarium Pump: étape 6, image 1 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 6, image 2 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 6, image 3 de 3
    • Using the Gorilla Glue, coat the diaphragm on both the inside and outside of the damaged area to ensure adhesion.
    • Make sure the entire area is covered as pictured - it's okay if it looks messy.
  7. How to Fix an Air Tech 2K0 Aquarium Pump: étape 7, image 1 de 1
    • Allow the glue to dry thoroughly before reassembling the air pump.
  8. How to Fix an Air Tech 2K0 Aquarium Pump: étape 8, image 1 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 8, image 2 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 8, image 3 de 3
    • From here, follow Step 4 in reverse to reassemble the diaphragm and its attached metal piece:
    • Insert the screw (1.25mm x 8mm) through the hole of the diaphragm.
    • Place the metal piece flush against the back of the diaphragm, making sure to line up the screw with the hole.
    • Finally, screw the washer back on to ensure a secure fit between all the pieces.
  9. How to Fix an Air Tech 2K0 Aquarium Pump: étape 9, image 1 de 2 How to Fix an Air Tech 2K0 Aquarium Pump: étape 9, image 2 de 2
    • Place the reassembled diaphragm back into the slot you initially removed it from.
  10. How to Fix an Air Tech 2K0 Aquarium Pump: étape 10, image 1 de 1
    • Place the cover back on the air pump, lining up the holes for the three screws (13mm x 2.9mm).
  11. How to Fix an Air Tech 2K0 Aquarium Pump: étape 11, image 1 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 11, image 2 de 3 How to Fix an Air Tech 2K0 Aquarium Pump: étape 11, image 3 de 3
    • Place the three screws (2.9mm x 13mm) and use the Philips screwdriver to secure them in place.
    • Once the cover is on securely, you will be able to reconnect the tubing, and you should have bubbles!
Madeline Kovach
Membre depuis le 03/22/21
220 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S3-G9, Saloman Spring 2021 Membre de l'équipe UMass Dartmouth, Team S3-G9, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G9
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 37
Total : 1,125
