Aller au contenu principal
How to Fix iPhone X Face ID Not Working After Screen Replacement
Vidéo d'introduction
  1. How to Fix iPhone X Face ID Not Working After Screen Replacement, Malfunction: étape 1, image 1 de 1
    • The iPhone X shows an alert that says it is ‘unable to activate Face ID on this iPhone’.
    • When trying to setup Face ID on the iPhone X, we get the message 'Face ID is Not Available, try setting up Face ID later'.
    • Also, according to the feedback from our client, Face ID on the phone is available after being dropped. However, Face ID is not available after replacing of the display assembly.
    • Unavailable Face ID might be caused by improper operation when replacing the display assembly.
  2. How to Fix iPhone X Face ID Not Working After Screen Replacement, Diagnose: étape 2, image 1 de 1
    • Check the Infrared camera and dot projector module under Microscope. Nothing goes wrong.
    • Let’s move to the Flood illuminator module on the earpiece speaker and front sensor assembly.
    • We can see clearly that flex cable next to the Flood illuminator module is damaged.
  3. How to Fix iPhone X Face ID Not Working After Screen Replacement, Troubleshoot: étape 3, image 1 de 1
    • Now, we need to separate the earpiece speaker from the assembly.
    • Remove the ambient light sensor module flex cable afterwards.
  4. How to Fix iPhone X Face ID Not Working After Screen Replacement, Troubleshoot: étape 4, image 1 de 1
    • Turn the flex cable upside-down and secure it again. Remove the Flood illuminator module.
    • Prepare a new flex cable. Apply some Paste Flux to the bonding pad and solder the detached Flood illuminator module.
  5. How to Fix iPhone X Face ID Not Working After Screen Replacement, Troubleshoot: étape 5, image 1 de 1
    • Solder the detached ambient light sensor module flex cable.
    • Now we need to solder the earpiece speaker back to flex cable and get it installed to the display assembly. Secure with screws afterwards.
  6. How to Fix iPhone X Face ID Not Working After Screen Replacement, Test: étape 6, image 1 de 1
    • Go to Settings > Face ID & Passcode > Reset Face ID. Face ID can be setup successfully
To fully understand Face ID, you can also check Face ID Teardown here.
22 autres ont terminé cette réparation.
Phryne
Membre depuis le 11/17/19
20 329 Réputation
18 tutoriels rédigés
7 commentaires
Why not just buy a new cable? They’re $10-$15 on eBay. Soldering seems like it’s take way more time and possibly even cost more money than just buying a new cable.
brian - Réponse
Face ID will no longer function if the original flex connectors are damaged or replace with new ones. Even if the flex connectors are properly soldered just as they were originall it will still fail. There is some marker in the cables which the module is checking for and if the cables are changed then the marker (most likely the serial number of the flex) will mismatch and fail to work. The same was true with Touch ID as well
James Sassu -
What brian said is correct, if the cable is changed it will not match.This full video looks more detailed(21) Troubleshooting iPhone X Problems of Floodlight Sensor, True Tone, and Face Recognition - YouTube
Kasis Cheng - Réponse
%#*!^@ I hope I didnt damage the face id cable during my battery change 😩 I sealed it up as well so it'll be a pain to open it up again to double check
pokoro - Réponse
Why my Face ID is not work what I we use to do it again
Lawrence - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 159
7 derniers jours : 1,208
30 derniers jours : 5,276
Total : 311,752
