Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
iPhone X touchscreen unresponsive is one of the most commonly seen cases in iPhone repair. Generally speaking, there are two different touch failure cases. Touch failure of the screen or abnormal transmission of the touch signal from the motherboard to CPU. Today we are teaching you how to rule out and get the problem fixed by starting with simple, then complex.
Vidéo d'introduction
  1. Replace with a new, undamaged screen and test. Touchscreen of the phone is responsive this time.
    • Replace with a new, undamaged screen and test. Touchscreen of the phone is responsive this time.
    • We can confirm that the problem is related to the original display assembly.
  2. Check the original display assembly. We can see that the touch flex cable and the touch connector look fine. There is nothing unusual on the bonding area.
    • Check the original display assembly. We can see that the touch flex cable and the touch connector look fine. There is nothing unusual on the bonding area.
    • Judging by this, the fault is probably caused by the touch IC or the screen.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. Let’s replace with a new touch IC and see how it works.
    • Let’s replace with a new touch IC and see how it works.
  5. Assemble the phone and test.
    • Assemble the phone and test.
    • The phone turns on normally. Touch screen of the phone is back to normal.
Phryne
Membre depuis le 17/11/2019
10 221 Réputation
80 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 142
Total : 1,208
