Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Increase the Waist Size of Jeans
Ce dont vous avez besoin
    1. How to Increase the Waist Size of Jeans, How to Increase the Waist Size of Jeans: étape 1, image 1 de 1
      • Lay the jeans on a flat surface.
      • Use a measuring tape to measure the waistband of the jeans from one hip to hip.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Increase the Waist Size of Jeans: étape 2, image 1 de 1
      • With the measuring tape, measure your own waistline from hip to hip.
      Demander à FixBot
    3. How to Increase the Waist Size of Jeans: étape 3, image 1 de 1
      • Calculate the difference between your waistline and the waistband measurements.
      • Mark 1/4 of the difference on each side of the waistband with a pencil.
      • For example, if the difference is 1 inch, mark 1/4 inch on each hip.
      Demander à FixBot
    4. How to Increase the Waist Size of Jeans: étape 4, image 1 de 2 How to Increase the Waist Size of Jeans: étape 4, image 2 de 2
      • Use sewing scissors to cut from 1/2 inch below the waistband to the marking made in Step 3.
      • Scissors may be sharp and should be used carefully.
      Demander à FixBot
    5. How to Increase the Waist Size of Jeans: étape 5, image 1 de 2 How to Increase the Waist Size of Jeans: étape 5, image 2 de 2
      • Measure the elastic to fit the space that was removed from the waistband with an extra 1/2 inch on each end.
      • Cut the elastic where it was measured.
      Demander à FixBot
    6. How to Increase the Waist Size of Jeans: étape 6, image 1 de 2 How to Increase the Waist Size of Jeans: étape 6, image 2 de 2
      • Insert an arms-length piece of thread through the needle's eye.
      • Pull it through the needle so both ends of the thread meet.
      • Tie a knot at the end of the thread.
      • The sewing needle is sharp and should be used carefully.
      Demander à FixBot
    7. How to Increase the Waist Size of Jeans: étape 7, image 1 de 2 How to Increase the Waist Size of Jeans: étape 7, image 2 de 2
      • Sew each end of the elastic on the inside of the waistband.
      • This can be done by inserting the needle back and forth through the elastic and jean waistband. Refer to this guide for information on how to hand sew a straight stitch.
      Demander à FixBot
    8. How to Increase the Waist Size of Jeans: étape 8, image 1 de 1
      • Tie a knot at the end of the thread when you finish sewing. Cut off the excess thread.
      • Repeat steps 3-8 on the alternate side of the waistband.
      Demander à FixBot
There you have it, an up-cycled pair of jeans that you can wear proudly instead of throwing away!
2 autres ont terminé cette réparation.
Katy Lawlor
Membre depuis le 04/26/24
193 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-2, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 4-2, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G2
3 membres
1 tutoriel rédigé
1 commentaire de tutoriel
Porque no lo traducen en español
Alberto - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 25
30 derniers jours : 87
Total : 1,817
