Aller au contenu principal
How to Install Handlebar Tape
Ce dont vous avez besoin
  1. How to Install Handlebar Tape, How to Install Handlebar Tape: étape 1, image 1 de 2 How to Install Handlebar Tape, How to Install Handlebar Tape: étape 1, image 2 de 2
    • Flip the hood of the brake lever upwards.
  2. How to Install Handlebar Tape: étape 2, image 1 de 3 How to Install Handlebar Tape: étape 2, image 2 de 3 How to Install Handlebar Tape: étape 2, image 3 de 3
    • Peel off the adhesive covering from the back of the bar tape.
    • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
    • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
  3. How to Install Handlebar Tape: étape 3, image 1 de 2 How to Install Handlebar Tape: étape 3, image 2 de 2
    • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
  4. How to Install Handlebar Tape: étape 4, image 1 de 2 How to Install Handlebar Tape: étape 4, image 2 de 2
    • Continue to tightly wrap the bar tape around the bar as evenly as possible.
    • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
  5. How to Install Handlebar Tape: étape 5, image 1 de 3 How to Install Handlebar Tape: étape 5, image 2 de 3 How to Install Handlebar Tape: étape 5, image 3 de 3
    • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
  6. How to Install Handlebar Tape: étape 6, image 1 de 3 How to Install Handlebar Tape: étape 6, image 2 de 3 How to Install Handlebar Tape: étape 6, image 3 de 3
    • Continue wrapping over lever.
    • Keep in mind the tightness and evenness of space between each wrap as you continue.
  7. How to Install Handlebar Tape: étape 7, image 1 de 2 How to Install Handlebar Tape: étape 7, image 2 de 2
    • Flip the break lever hood back down and continue.
  8. How to Install Handlebar Tape: étape 8, image 1 de 2 How to Install Handlebar Tape: étape 8, image 2 de 2
    • Stop wrapping about 2 inches from stem.
  9. How to Install Handlebar Tape: étape 9, image 1 de 3 How to Install Handlebar Tape: étape 9, image 2 de 3 How to Install Handlebar Tape: étape 9, image 3 de 3
    • Cut the bar tape diagonally at an approximately 60 degree angle.
  10. How to Install Handlebar Tape: étape 10, image 1 de 1
    • Finish the wrap.
    • The cut should make the end of the bar tape a straight line.
  11. How to Install Handlebar Tape: étape 11, image 1 de 3 How to Install Handlebar Tape: étape 11, image 2 de 3 How to Install Handlebar Tape: étape 11, image 3 de 3
    • Use the electrical tape provided to tightly secure the end of the wrap.
  12. How to Install Handlebar Tape: étape 12, image 1 de 3 How to Install Handlebar Tape: étape 12, image 2 de 3 How to Install Handlebar Tape: étape 12, image 3 de 3
    • Press down on electrical tape to secure it.
  13. How to Install Handlebar Tape: étape 13, image 1 de 3 How to Install Handlebar Tape: étape 13, image 2 de 3 How to Install Handlebar Tape: étape 13, image 3 de 3
    • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
Ligne d'arrivée
Elizabeth Hall
Membre depuis le 04/28/17
131 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S2-G7, Cole Spring 2017 Membre de l'équipe UC Davis, Team S2-G7, Cole Spring 2017
UCD-COLE-S17S2G7
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 24
Total : 3,974
