Introduction
This guide is perfect for someone who is new to Ubuntu and would like to try it.
Ce dont vous avez besoin
Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
If you have successfully booted into the installation media, you will see this picture.
Click on the big "Install Ubuntu" button.
After a screen asking about additional software, you will asked what you would like to do with your hard disk.
If you are experienced with partitions, you may use this partition editor.
That's it! Now you can try Ubuntu all you want.
7 autres ont terminé cette réparation.
