Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide shows how to install a 2.5-inch hard drive into the aluminum enclosure sold by iFixit. The enclosure can hold either a SSD or a standard 2.5-inch (platter) hard drive, as long as they have the proper SATA connectors.
If you have a silicone enclosure, follow this guide instead.
  1. Before you begin, look at your hard drive's ports and make sure that it has the right connectors:
    • Before you begin, look at your hard drive's ports and make sure that it has the right connectors:
    • Narrow data port
    • Wide power port
  2. Use the included screwdriver to remove the two Phillips screws.
    • Use the included screwdriver to remove the two Phillips screws.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Slide the plastic tray out of the aluminum housing. Slide the plastic tray out of the aluminum housing.
    • Slide the plastic tray out of the aluminum housing.
  5. Set the drive in the plastic tray and align the drive ports with the tray socket. To prevent strain on the enclosure socket, lay the drive as flat against the tray as possible. Carefully push the drive into the tray socket to seat the ports.
    • Set the drive in the plastic tray and align the drive ports with the tray socket.
    • To prevent strain on the enclosure socket, lay the drive as flat against the tray as possible.
    • Carefully push the drive into the tray socket to seat the ports.
    • Press the drive's raised edge down into the plastic tray.
    • If the drive edge catches on the foam block, the drive is not fully seated against the tray socket. Continue pressing the drive into the socket until it clears the foam block.
  6. Flip the drive tray over.
    • Flip the drive tray over.
    • Use the a Phillips screwdriver to install the four mounting screws (included in the kit) to secure the drive to the tray.
  7. Slide the tray back into the aluminum housing. Reinstall the two Phillips screws to secure the tray. Reinstall the two Phillips screws to secure the tray.
    • Slide the tray back into the aluminum housing.
    • Reinstall the two Phillips screws to secure the tray.
Your drive is ready to be used!
4 autre(s) ont terminé cette réparation.
Arthur Shi
Membre depuis le 03/01/2018
116 076 Réputation
340 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
125 membres
11 816 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 17
7 derniers jours : 160
30 derniers jours : 817
Total : 3,027
