Aller au contenu principal
How to Install a Fifth String Shubb Banjo Capo
Ce dont vous avez besoin
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: étape 1, image 1 de 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: étape 1, image 2 de 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: étape 1, image 3 de 3
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: étape 2, image 1 de 1
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: étape 3, image 1 de 1
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: étape 4, image 1 de 2 How to Install a Fifth String Shubb Banjo Capo: étape 4, image 2 de 2
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: étape 5, image 1 de 3 How to Install a Fifth String Shubb Banjo Capo: étape 5, image 2 de 3 How to Install a Fifth String Shubb Banjo Capo: étape 5, image 3 de 3
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 autres ont terminé cette réparation.
Sara Wier
Membre depuis le 02/24/15
263 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 23-4, Green Winter 2015 Membre de l'équipe Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 52
Total : 6,845
