Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Install a Front Load Washer Door Boot Seal Using a Homemade Tool
Tutoriel vidéo
Ce tutoriel a été transcrit à partir d'une vidéo YouTube.
Ce dont vous avez besoin
    • Unplug the washer before working around the door opening.
    • Turn off the water supply valves if you’ll be moving hands near hoses or the dispenser area.
    • Wear gloves and keep your face and fingers out of the spring’s path because the clamp can snap back and pinch you.
    • This method is most helpful for the outer, smaller spring clamp, but it can also be used on the inner spring clamp if needed.
    Demander à FixBot
    • Get a standard wrench that gives you enough leverage and width for the clamp, such as a 5/8-inch wrench or slightly larger.
    • Get two heavy-duty cable ties that are wide and strong, but still fit through the clamp’s eyelets.
    • Get needle-nose pliers to tighten the ties and help press the clamp into place.
    • Get side cutters, scissors, or another sharp cutter to remove the ties after the clamp is installed.
    • Optionally wrap masking tape around the tips of the pliers or a screwdriver to reduce the chance of nicking the rubber boot or scraping the washer’s metal.
    Demander à FixBot
    • Thread a cable tie through the box end (socket end) of the wrench.
    • Thread that cable tie through one eyelet of the door boot spring clamp.
    • Loosely latch the cable tie so the wrench and spring eyelet stay connected but can still shift.
    • Keep the spring mostly on one side of the wrench for the entire setup so it doesn’t twist into an unworkable position.
    • Diagram: [eyelet]—(tie)—[wrench box end], with the spring sitting to one side of the wrench instead of centered across it.
    Demander à FixBot
    • Thread the second cable tie through the other eyelet of the spring clamp.
    • Loosely latch that tie around the open end (mouth) of the wrench on the opposite side.
    • Work both ties tighter to begin spreading the spring clamp while keeping the spring mostly on the same side of the wrench.
    • Hand-tighten as far as you can, then use needle-nose pliers to pull the ties tighter for more leverage.
    • Caution: If a cable tie fails under tension, the spring can snap back and pinch you.
    Demander à FixBot
    • Grab the flat tail of the tie on the wrench mouth side with needle-nose pliers.
    • Use the tip of the wrench as a pivot point and lever the pliers to ratchet the tie tighter and spread the spring wider.
    • Repeat the same leverage method on the box end side if needed, but expect it to be a bit more difficult than the mouth side.
    • Stop tightening once the spring clamp is spread wide enough to attempt installation without forcing the boot out of its groove.
    • Diagram: [eyelet]—(tie)—[wrench box end] <——spring spread——> [wrench open end]—(tie)—[eyelet].
    Demander à FixBot
    • Press the door boot seal fully onto the washer’s front lip so it sits snug and even all the way around.
    • Lay the wire clamp around the boot seal and seat it into the same groove it came out of.
    • Aim the spring and wrench inward toward the washer housing as you work the clamp into the groove.
    • Work around the boot until you reach the area where the spring was originally positioned, which is often near the bottom and sometimes slightly offset depending on the brand.
    Demander à FixBot
    • At the spring area, press the wire and spring into the groove by hand to start it.
    • Use needle-nose pliers to press against the boot seal and push the spring and wrench inward until the clamp drops into the groove.
    • Press lightly and work from the outside of the spring toward the inside so you don’t slip and damage the rubber.
    • Optionally use a taped screwdriver tip to help press the wire and spring into place if pliers can’t reach comfortably.
    • If the clamp doesn’t pop in, press directly on the spring with the pliers or pivot the pliers toward the drum to help it seat.
    Demander à FixBot
    • Hold the wrench and spring steady so the clamp stays seated in the groove.
    • Cut both cable ties.
    • Use needle-nose pliers to pull the cut ties out of the wire clamp and away from the boot.
    Demander à FixBot
Confirm the boot seal and spring clamp stay fully seated before returning the washer to service. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
Membre depuis le 01/21/25
6 551 Réputation
224 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 82
30 derniers jours : 201
Total : 536
